Identify the component
Has thanked: 10971 times
Been thanked: 4004 times
Wots dis fing?
I found it under my car this morning, but not sure it's off the car because it's absolutely pristine.
Ditchfinder
Has thanked: 862 times
Been thanked: 1071 times
Re: Identify the component
Post by Ditchfinder »
Brake pad retaining clip?
Ditchfinder
Or part of a watch bracelet
Been thanked: 9505 times
I think it's a piece of trim off a jubilee clamp.
Like inside this one...
Been thanked: 2730 times
Probably what KFB said, I can't see the picture he posted.
60-80mm Norma T Bolt clamp. Part number 4:
It's this I think...
Screenshot 2024-10-06 143647.png (85.75 KiB) Viewed 1635 times
They grip really well cylindrically over their limited size range. You have to suit the clamp to the hose. I used them on my biodiesel plant, much better then the usual Jubilee clip, but more expensive.
KFB is righter than me.
My van's intercooler hoses use the type KFB has shown.
Might be stainless, have you tried a magnet on it?
Has thanked: 316 times
Been thanked: 1078 times
Post by Silly Car »
Clearly it is a pingfuckit otherwise it wouldn’t be loose under your car. :D
I'm now wondering where it might have come from.
As said, it's absolutely pristine, which makes me think it's NOT come from something under the bonnet.
If it's a tension spring from a jubilee clip, that would indicate that (if it came from the car), there's now a loose bit of pipe somewhere....
Is does your car have an intercooled turbo engine?
If so it could be from an intercooler hose clip.
KungFooBob wrote: Sun Oct 06, 2024 6:22 pm does your car have an intercooled turbo engine?
It used to.
KungFooBob wrote: Sun Oct 06, 2024 6:22 pm Is does your car have an intercooled turbo engine?
Errrr, it's a VW Eos 1.4 TSI.... So.... Possibly?
Rockburner wrote: Sun Oct 06, 2024 7:07 pm
TSI = Turbocharged Stratified Injection.
I'd give it a really good boot on a quiet stretch of road, see if it's lacking any performance (an getting terrible MPG).
If an intercooler pipe pipe has come loose you'll know about it without giving it a boot because it'll whistle or chuff like a good 'un and it will probably make the EGM light come on.
But the pipe might not have come off yet.
Without the clip, if he gives it a good boot it will :)
KungFooBob wrote: Sun Oct 06, 2024 7:10 pm
Hmmmm
The air-valve that controls intake from either the super- or turbo-charger is already behaving like a teenager, so maybe it's time to get the thing properly looked at
KungFooBob wrote: Sun Oct 06, 2024 7:17 pm But the pipe might not have come off yet.
How to solve an intermittent or possible problem.
