Identify the component
- Has thanked: 7609 times
- Been thanked: 2452 times
I found it under my car this morning, but not sure it's off the car because it's absolutely pristine.
- Ditchfinder
- Has thanked: 591 times
- Been thanked: 664 times
Re: Identify the component
Brake pad retaining clip?
- Ditchfinder
Or part of a watch bracelet
- Has thanked: 532 times
- Been thanked: 7408 times
I think it's a piece of trim off a jubilee clamp.
Like inside this one...
- Been thanked: 2572 times
Probably what KFB said, I can't see the picture he posted.
60-80mm Norma T Bolt clamp. Part number 4:
It's this I think...
- Screenshot 2024-10-06 143647.png (85.75 KiB) Viewed 702 times
They grip really well cylindrically over their limited size range. You have to suit the clamp to the hose. I used them on my biodiesel plant, much better then the usual Jubilee clip, but more expensive.
KFB is righter than me.
My van's intercooler hoses use the type KFB has shown.
I'm now wondering where it might have come from.
As said, it's absolutely pristine, which makes me think it's NOT come from something under the bonnet.
If it's a tension spring from a jubilee clip, that would indicate that (if it came from the car), there's now a loose bit of pipe somewhere....
Is does your car have an intercooled turbo engine?
If so it could be from an intercooler hose clip.
- Has thanked: 2530 times
- Been thanked: 6126 times
Errrr, it's a VW Eos 1.4 TSI.... So.... Possibly?KungFooBob wrote: ↑Sun Oct 06, 2024 6:22 pm Is does your car have an intercooled turbo engine?
TSI = Turbocharged Stratified Injection.Rockburner wrote: ↑Sun Oct 06, 2024 7:07 pmErrrr, it's a VW Eos 1.4 TSI.... So.... Possibly?KungFooBob wrote: ↑Sun Oct 06, 2024 6:22 pm Is does your car have an intercooled turbo engine?
I'd give it a really good boot on a quiet stretch of road, see if it's lacking any performance (an getting terrible MPG).
If an intercooler pipe pipe has come loose you'll know about it without giving it a boot because it'll whistle or chuff like a good 'un and it will probably make the EGM light come on.
But the pipe might not have come off yet.
Without the clip, if he gives it a good boot it will
HmmmmKungFooBob wrote: ↑Sun Oct 06, 2024 7:10 pmTSI = Turbocharged Stratified Injection.Rockburner wrote: ↑Sun Oct 06, 2024 7:07 pmErrrr, it's a VW Eos 1.4 TSI.... So.... Possibly?KungFooBob wrote: ↑Sun Oct 06, 2024 6:22 pm Is does your car have an intercooled turbo engine?
The air-valve that controls intake from either the super- or turbo-charger is already behaving like a teenager, so maybe it's time to get the thing properly looked at
How to solve an intermittent or possible problem.KungFooBob wrote: ↑Sun Oct 06, 2024 7:17 pm But the pipe might not have come off yet.
