2CV6 Project Thread
Buckaroo
Has thanked: 1047 times
Been thanked: 1108 times
Re: 2CV6 Project Thread
Post by Buckaroo »
Sure was! I part exchanged it without telling Mrs. She was beyond angry 😠.
The red and white was new from Middleton motors in Potters Bar. We added so many accessories to it, it was a wonder how it actually moved. The kids loved both Dollys.
I still have the original paperwork and owners manual.
Ah, but that specific Dolly is a movie star!
Has thanked: 1183 times
Been thanked: 2277 times
MingtheMerciless wrote: Tue Jul 15, 2025 12:23 pm Will you be fitting an oil temp gauge? Loving this project and a "car" mate a work is interested as well.
Yes. There is a sender on the engine so I just need to work out the specs of the sender or find one that's paired with a gauge that fits.
katana
Has thanked: 77 times
Been thanked: 54 times
Post by katana »
dern wrote: Tue Jul 15, 2025 4:28 pm
From a couple of wierdos I know in the citreon club, you aren't alone in the BMW air/oil head engines. Tho both had cooling issues with the bmw engine, which were over come by either modifying the front to have slats? in bonnet or the front to have the heads in the air flow.
Tho both ran the cars as standard as possible initially for shits a giggles as the the more powerful engine made the 2cv in to real sleepers. You would not beleive the negative reaction/anger from being out accelerated by a 2cv. Especially with two idiots laughing.
I also know of a bmw engined 2cv with nitrous. Both fun and fucking scary.
katana wrote: Tue Jul 15, 2025 11:00 pm From a couple of wierdos I know in the citreon club, you aren't alone in the BMW air/oil head engines. Tho both had cooling issues with the bmw engine, which were over come by either modifying the front to have slats? in bonnet or the front to have the heads in the air flow.
This is an example of the cooling setup that I'll copy...
Screenshot 2025-07-16 at 10.55.22.png (2.71 MiB) Viewed 2046 times
Been thanked: 3504 times
Any updates @dern or back-burner for now. ?
Has thanked: 7615 times
katana wrote: Tue Jul 15, 2025 11:00 pm You would not beleive the negative reaction/anger from being out accelerated by a 2cv.
I knew someone who dropped a 1300 Marina engine into a Moggie Minor (and uprated the brakes).
Similar indignation :)
Some progress but not much recently, been busy.
Rebuilt the gearbox with a new selector and oil seals and fitted back to the engine. Engine is sort of in the chassis with the front cross member notched to allow it to fit. Driveshafts rebuilt and fitted. Playing around with making exhaust bends with piecuts because it looked fun to do.
Next job is to get the height of the engine correct and build engine mounts.
Trial fitted the wings to ensure that the engine is in the right place and at the right height. The engine is wide so I'm going to have to adjust the wings to make them fit. I'm obviously super excited about trying to get those exhaust studs out and have already ordered new studs and a helicoil kit.
I've also started to make the engine cradle. I played with the lathe to create some bushes and welded them in to box section to hold one of the engine mounting bolts. I've installed some generic engine mounts into the front cross member and made some plates to sit on top of them to weld the cradle to. There will be plenty of bracing, and I'll pick up another mounting point on the engine (the hole just below the alternator).
I'll see how much this lets the engine rock side to side. I'm reasonably sure it'll be ok, but I have options if this isn't enough. I want to leave enough room to the side to route the exhaust that I need to build next.
Has thanked: 3644 times
Been thanked: 2502 times
Really enjoying this project, keep the updates coming please.
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
Did you see the one in Mathewsons
You need someone to 3D print you a timing cover with a Citroen logon on it :)
I scrapped the engine mounts I made. I wasn’t happy with them so did some destructive testing on them and they were bomb proof. Made some more over the last couple of weekends so pending tidying and painting, the engine mounts are done. I’ll probably be hanging the oil cooler from the engine mount cradle so won’t be painting them yet.
Exhaust next. Bought myself a chop saw with some carbide tipped blades for steel and stainless steel which is making this job a ton easier.
all done with JB Weld :)
KungFooBob wrote: Sun Mar 01, 2026 6:55 pm all done with JB Weld :)
:lol:
Has thanked: 2287 times
Been thanked: 2673 times
Horse wrote: Mon Jan 19, 2026 8:43 am
People used to drop Rover V8's in them...
Has thanked: 2556 times
Been thanked: 4167 times
ZRX61 wrote: Mon Mar 02, 2026 11:47 pm
The Fiat/Lancia Twin Cam 2 litre engine was another popular donor, Volumex optional...
Nothing very exciting this weekend. Something I've not looking forward was to remove the old broken exhaust manifold studs and replace with new. In the event 1 just came out with the bolt rusted to it, 1 came out after I welded a nut to the stud and 3 either snapped when I removed the manifold when I dismantled the bike or snapped when I tried to remove them by welding nuts to the studs. The last one just refused to move or snap, I just got the nut stuck on it after either stripping the threads in the nut or on the stud. The last 4 needed drilling out and helicoiling. No drama happened, it was straight forward and pretty satisfying. Here's some pictures...
Has thanked: 10959 times
Been thanked: 3995 times
dern wrote: Sun Mar 08, 2026 7:50 pm Nothing very exciting this weekend. Something I've not looking forward was to remove the old broken exhaust manifold studs and replace with new. In the event 1 just came out with the bolt rusted to it, 1 came out after I welded a nut to the stud and 3 either snapped when I removed the manifold when I dismantled the bike or snapped when I tried to remove them by welding nuts to the studs. The last one just refused to move or snap, I just got the nut stuck on it after either stripping the threads in the nut or on the stud. The last 4 needed drilling out and helicoiling. No drama happened, it was straight forward and pretty satisfying. Here's some pictures...
Well done for sorting that. Its a known issues on these engines. Usomg the aluslip stuff is, i think, the best solution when reassembling.
