ZXR 750 L1
Has thanked: 9828 times
Been thanked: 10145 times
Re: ZXR 750 L1
dern wrote: Sun Feb 06, 2022 6:11 pm The best thing about doing the clearances on this bike is that the rockers push to one side so you don't have to remove the cams. Huge time saver. You can see the springs in this picture...
Same as the ZZR1100,it makes valves clearances a doddle.
Has thanked: 2551 times
Been thanked: 6245 times
Re: ZXR 750 L1
I'll tell you what makes valve clearances a doddle.
Pushrods!
Been thanked: 7530 times
Re: ZXR 750 L1
Hydraulic tappets!
Re: ZXR 750 L1
I'll tell you what makes valve clearances a doddle, two strokes.
Weird having rockers with bucket and shim valves.
BBB
Has thanked: 292 times
Been thanked: 79 times
Re: ZXR 750 L1
Post by BBB »
How do the rockers slide? I'm struggling to visualise it as they look bolted in place.
Re: ZXR 750 L1
I assume they slide on the shafts with the springs on them (don't confuse the followers with the cams/lobes)
Desmo followers on the aircooled heads slide on the shaft once a clip is removed.
BBB
Re: ZXR 750 L1
Post by BBB »
Got you, didn't see the followers, had stupidly thought shim and bucket. Makes sense now, thank you.
Has thanked: 2405 times
Been thanked: 3630 times
Re: ZXR 750 L1
Mr. Dazzle wrote: Sun Feb 06, 2022 8:27 pm I'll tell you what makes valve clearances a doddle.
Pushrods!
Probably because you have to adjust them every five minutes... :D
Has thanked: 1016 times
Been thanked: 1767 times
Re: ZXR 750 L1
KungFooBob wrote: Sun Feb 06, 2022 8:41 pm I'll tell you what makes valve clearances a doddle.
Hydraulic tappets!
True. I'll do a mondeo next ;)
Re: ZXR 750 L1
Thanks to a superb facebook zxr group I've now got a new zx7r sleeve with adapters and a replacement pivot bolt on the way. Didn't mention the pivot bolt but the threads have been forced at some point and are somewhat damaged.
Re: ZXR 750 L1
Pushrods!
dern wrote: Mon Feb 07, 2022 8:27 am
Hydraulic tappets!
My Enfield has pushrods and hydraulic tappets.
WIN/WIN!
Re: ZXR 750 L1
KungFooBob wrote: Mon Feb 07, 2022 8:37 am My Enfield has pushrods and hydraulic tappets.
WIN/WIN!
They really don't want those valves to move quickly.
Re: ZXR 750 L1
Looks like whoever did the swing arm bearings last time lubricated them with copperslip!
Re: ZXR 750 L1
Should have bought this one instead.
No restoration required :)
https://iconicmotorbikeauctions.com/auc ... -in-crate/
Re: ZXR 750 L1
Were the model designations different for Murkins? That is clearly a ZXR750-K2 but the auctioneers are touting it as a ZX-7R.
Re: ZXR 750 L1
Crazy dough.
Has thanked: 10265 times
Been thanked: 6886 times
Re: ZXR 750 L1
Skub wrote: Tue Feb 15, 2022 7:42 pmCrazy dough.
Re: ZXR 750 L1
Thankyou for that post - it made me remember that I have a loaf that's been in the airing cupboard for too long and needs to go in the oven... :mrgreen:
Re: ZXR 750 L1
Yorick wrote: Tue Feb 15, 2022 7:44 pm
I want toast now. :(
Re: ZXR 750 L1
Skub wrote: Tue Feb 15, 2022 7:59 pm
