Same as the ZZR1100,it makes valves clearances a doddle.dern wrote: Sun Feb 06, 2022 6:11 pm The best thing about doing the clearances on this bike is that the rockers push to one side so you don't have to remove the cams. Huge time saver. You can see the springs in this picture...
ZXR 750 L1
Re: ZXR 750 L1
- Been thanked: 9495 times
- Has thanked: 602 times
- Been thanked: 4528 times
Re: ZXR 750 L1
I'll tell you what makes valve clearances a doddle, two strokes.
Weird having rockers with bucket and shim valves.
Re: ZXR 750 L1
I assume they slide on the shafts with the springs on them (don't confuse the followers with the cams/lobes)
Desmo followers on the aircooled heads slide on the shaft once a clip is removed.
- Has thanked: 2556 times
- Been thanked: 4167 times
Re: ZXR 750 L1
Probably because you have to adjust them every five minutes...Mr. Dazzle wrote: Sun Feb 06, 2022 8:27 pm I'll tell you what makes valve clearances a doddle.
Pushrods!
- dern
- Has thanked: 1183 times
- Been thanked: 2277 times
Re: ZXR 750 L1
True. I'll do a mondeo nextKungFooBob wrote: Sun Feb 06, 2022 8:41 pm I'll tell you what makes valve clearances a doddle.
Hydraulic tappets!
- dern
Re: ZXR 750 L1
Thanks to a superb facebook zxr group I've now got a new zx7r sleeve with adapters and a replacement pivot bolt on the way. Didn't mention the pivot bolt but the threads have been forced at some point and are somewhat damaged.
Re: ZXR 750 L1
Pushrods!
My Enfield has pushrods and hydraulic tappets.dern wrote: Mon Feb 07, 2022 8:27 amTrue. I'll do a mondeo nextKungFooBob wrote: Sun Feb 06, 2022 8:41 pm I'll tell you what makes valve clearances a doddle.
Hydraulic tappets!![]()
WIN/WIN!
- dern
Re: ZXR 750 L1
Looks like whoever did the swing arm bearings last time lubricated them with copperslip!
Re: ZXR 750 L1
Should have bought this one instead.
No restoration required
https://iconicmotorbikeauctions.com/auc ... -in-crate/
Re: ZXR 750 L1
Were the model designations different for Murkins? That is clearly a ZXR750-K2 but the auctioneers are touting it as a ZX-7R.
Re: ZXR 750 L1
Crazy dough.
- Has thanked: 12606 times
- Been thanked: 8536 times
Re: ZXR 750 L1
Thankyou for that post - it made me remember that I have a loaf that's been in the airing cupboard for too long and needs to go in the oven...
Re: ZXR 750 L1
I want toast now.
