Same as the ZZR1100,it makes valves clearances a doddle.
ZXR 750 L1
- Has thanked: 9827 times
- Been thanked: 10145 times
Re: ZXR 750 L1
- Has thanked: 2551 times
- Been thanked: 6244 times
- Been thanked: 7530 times
- Been thanked: 4124 times
Re: ZXR 750 L1
I'll tell you what makes valve clearances a doddle, two strokes.
Weird having rockers with bucket and shim valves.
Re: ZXR 750 L1
I assume they slide on the shafts with the springs on them (don't confuse the followers with the cams/lobes)
Desmo followers on the aircooled heads slide on the shaft once a clip is removed.
- Has thanked: 2405 times
- Been thanked: 3630 times
Re: ZXR 750 L1
Probably because you have to adjust them every five minutes...Mr. Dazzle wrote: ↑Sun Feb 06, 2022 8:27 pm I'll tell you what makes valve clearances a doddle.
Pushrods!
- dern
- Has thanked: 1016 times
- Been thanked: 1767 times
Re: ZXR 750 L1
True. I'll do a mondeo nextKungFooBob wrote: ↑Sun Feb 06, 2022 8:41 pm I'll tell you what makes valve clearances a doddle.
Hydraulic tappets!
- dern
Re: ZXR 750 L1
Thanks to a superb facebook zxr group I've now got a new zx7r sleeve with adapters and a replacement pivot bolt on the way. Didn't mention the pivot bolt but the threads have been forced at some point and are somewhat damaged.
Re: ZXR 750 L1
Pushrods!
My Enfield has pushrods and hydraulic tappets.dern wrote: ↑Mon Feb 07, 2022 8:27 amTrue. I'll do a mondeo nextKungFooBob wrote: ↑Sun Feb 06, 2022 8:41 pm I'll tell you what makes valve clearances a doddle.
Hydraulic tappets!
WIN/WIN!
- dern
Re: ZXR 750 L1
Looks like whoever did the swing arm bearings last time lubricated them with copperslip!
Re: ZXR 750 L1
Should have bought this one instead.
No restoration required
https://iconicmotorbikeauctions.com/auc ... -in-crate/
Re: ZXR 750 L1
Were the model designations different for Murkins? That is clearly a ZXR750-K2 but the auctioneers are touting it as a ZX-7R.
Re: ZXR 750 L1
Crazy dough.
- Has thanked: 10263 times
- Been thanked: 6886 times
Re: ZXR 750 L1
Thankyou for that post - it made me remember that I have a loaf that's been in the airing cupboard for too long and needs to go in the oven...
Re: ZXR 750 L1
I want toast now.
