Who's cooking with Cast Iron?
Anything from pizza to pasta, from steak to cake.
Has thanked: 1524 times
Been thanked: 1432 times
What ya got?
Picked up these two today for a mere pittance.
Has thanked: 1952 times
Been thanked: 1295 times
Re: Who's cooking with Cast Iron?
Post by Jody »
I've recently got one, I used it a bit, just on the hob for now as it's not quite BBQ weather. It's OK but I honestly can't see what the fuss is about.
moth
Has thanked: 336 times
Been thanked: 192 times
Post by moth »
Jody wrote: Mon May 03, 2021 8:31 am I've recently got one, I used it a bit, just on the hob for now as it's not quite BBQ weather. It's OK but I honestly can't see what the fuss is about.
Raw cast iron pans like Rick's (I hope he's got a sand blaster) can be heated to a very high heat without them buckling/melting. Having got fecking hot, they tend to stay hot for quite a while.
Enameled or non stick coated cast iron, like Le Creuset, not so much. Although I do have a BFO Le Creuset raw cast iron griddle plate that's ace for cooking steak. And for arm, chest and shoulder workouts.
Proud Tory scum since 1974.
Post by Jody »
moth wrote: Mon May 03, 2021 9:25 am
Mine is Branded Le Crusset and weighs a ton so I've assumed it is cast?
moth
Post by moth »
Summat like this? It's cast iron.
They can be used on any heat source, including camp fires, are non-stick if treated/seasoned properly & don't have any of the nasties that (apparently) come with non-stick coatings.
moth wrote: Mon May 03, 2021 9:25 am Raw cast iron pans like Rick's (I hope he's got a sand blaster) can be heated to a very high heat without them buckling/melting. Having got fecking hot, they tend to stay hot for quite a while.
A TP960, but not using it for the pan resto/rescue. Elbow grease, vinegar & oven cleaner. I may use electrolysis next time after a week in the Lye bucket. :)
Yesterdays Lodge find is coming along nicely :) The Wagner is still *in process*
moth wrote: Mon May 03, 2021 11:48 am Summat like this? It's cast iron.
Looks to be coated with *something* & not actually seasoned.
Wagner is getting there...
moth
Post by moth »
ZRX61 wrote: Mon May 03, 2021 10:53 pm
It's not the same as mine - it's Le Creuset and fashions change dahhhhhling, but mine didn't come coated in owt. It got wiped over with groundnut oil and had a couple of goes in a very hot oven :)
Actual seasoning of the two skillets started today. They're getting wiped down with lard, then baked for an hour or so at 450deg & allowed to cool. At least three cycles depending on results, first cycle started. Pics when I'm done.
edit: 2nd cycle.
Been thanked: 2628 times
Wouldn't using old engine oil be more manly? Grrrr.
Kudos for starting a macho mumsnet thread.
cheb wrote: Tue May 04, 2021 7:44 pm Wouldn't using old engine oil be more manly? Grrrr.
I use old engine oil for tools :)
Has thanked: 604 times
Been thanked: 2470 times
Jody wrote: Mon May 03, 2021 8:31 am It's OK but I honestly can't see what the fuss is about.
Lovin' mine (cheap no name no history Amazon special), it's at home on the Weber, or on the fire box of the smoker or in the smoker, it retains heat bloody well when I'm pissing about, clean up with a wipe and most importantly for me doesn't melt.
Think I may play with a Dutch oven next and channel my inner Kent Rollins
Done for now, they got two cycles of lard/heat/cool down a bit...
Added two more pieces today...8in skillet for eggs & toasted sarnies & a 10.5 in grill pan for steaks :)
The 10 & 12in Lodge skillets I bought a few weeks ago, & yes, the 10 is identical to the other Lodge I just rescued.
Has thanked: 816 times
Been thanked: 4839 times
Boil-in-the-bag Vesta curry is where it's at.
More seasoning going on today & fried a couple of eggs in the 10in without any oil etc (successfully)
Got back from a Costco blow out last night & roomie says "They had a 5piece Lodge animal series for $85"
buggeration! Probably won't have it next time I go there...
