Who's cooking with Cast Iron?
- Has thanked: 1507 times
- Been thanked: 1412 times
- Has thanked: 1947 times
- Been thanked: 1292 times
Re: Who's cooking with Cast Iron?
I've recently got one, I used it a bit, just on the hob for now as it's not quite BBQ weather. It's OK but I honestly can't see what the fuss is about.
- moth
- Has thanked: 336 times
- Been thanked: 192 times
Raw cast iron pans like Rick's (I hope he's got a sand blaster) can be heated to a very high heat without them buckling/melting. Having got fecking hot, they tend to stay hot for quite a while.
Enameled or non stick coated cast iron, like Le Creuset, not so much. Although I do have a BFO Le Creuset raw cast iron griddle plate that's ace for cooking steak. And for arm, chest and shoulder workouts.
Proud Tory scum since 1974.
Mine is Branded Le Crusset and weighs a ton so I've assumed it is cast?moth wrote: ↑Mon May 03, 2021 9:25 amRaw cast iron pans like Rick's (I hope he's got a sand blaster) can be heated to a very high heat without them buckling/melting. Having got fecking hot, they tend to stay hot for quite a while.
They can be used on any heat source, including camp fires, are non-stick if treated/seasoned properly & don't have any of the nasties that (apparently) come with non-stick coatings.
A TP960, but not using it for the pan resto/rescue. Elbow grease, vinegar & oven cleaner. I may use electrolysis next time after a week in the Lye bucket.
Yesterdays Lodge find is coming along nicely The Wagner is still *in process*
- moth
It's not the same as mine - it's Le Creuset and fashions change dahhhhhling, but mine didn't come coated in owt. It got wiped over with groundnut oil and had a couple of goes in a very hot oven
Actual seasoning of the two skillets started today. They're getting wiped down with lard, then baked for an hour or so at 450deg & allowed to cool. At least three cycles depending on results, first cycle started. Pics when I'm done.
edit: 2nd cycle.
edit: 2nd cycle.
- Been thanked: 2615 times
Wouldn't using old engine oil be more manly? Grrrr.
Kudos for starting a macho mumsnet thread.
- Has thanked: 599 times
- Been thanked: 2429 times
Lovin' mine (cheap no name no history Amazon special), it's at home on the Weber, or on the fire box of the smoker or in the smoker, it retains heat bloody well when I'm pissing about, clean up with a wipe and most importantly for me doesn't melt.
Think I may play with a Dutch oven next and channel my inner Kent Rollins
Added two more pieces today...8in skillet for eggs & toasted sarnies & a 10.5 in grill pan for steaks
The 10 & 12in Lodge skillets I bought a few weeks ago, & yes, the 10 is identical to the other Lodge I just rescued.
- gremlin
- Has thanked: 808 times
- Been thanked: 4793 times
More seasoning going on today & fried a couple of eggs in the 10in without any oil etc (successfully)
Got back from a Costco blow out last night & roomie says "They had a 5piece Lodge animal series for $85"
buggeration! Probably won't have it next time I go there...
