DIY roller starter
Been thanked: 9496 times
Re: DIY roller starter
Do both rollers need to be driven, or is it just belt and braces?
derek badger
Has thanked: 1091 times
Been thanked: 1753 times
Post by derek badger »
Rockburner wrote: Thu May 20, 2021 3:14 pm I hope you're going to put a guard on that chain......
Yes, both sides.
derek badger
KungFooBob wrote: Thu May 20, 2021 3:19 pm Do both rollers need to be driven, or is it just belt and braces?
They don't have to, but it's better if they are both driven.
Has thanked: 781 times
Been thanked: 1072 times
derek badger wrote: Thu May 20, 2021 3:43 pm
Won't the back roller try to lift the back wheel up? I have no experience of these, just tend to look at stuff and work out how it is most likely to kill me.
derek badger
Mussels wrote: Thu May 20, 2021 4:44 pm
I've seen more twin drive starters than single ones so they must be okay. I'll make sure to film the first run though. :thumbup:
iansoady
Has thanked: 72 times
Been thanked: 244 times
Post by iansoady »
Looking scary......
derek badger
iansoady wrote: Fri May 21, 2021 10:23 am Looking scary......
Has thanked: 1080 times
Been thanked: 1010 times
Post by slowsider »
You still in one piece, DB ?
derek badger
slowsider wrote: Tue May 25, 2021 11:33 am You still in one piece, DB ?
Yea, I had to send the hound out to pick up some Argon/5% CO2 gas. I've got a day off work coming up soon so I'll make a start on the welding then.
TightRS
Has thanked: 101 times
Been thanked: 13 times
Post by TightRS »
I was just thinking, I wonder if you could wrap a rope around the tyre and pull start it. Of course, there's a video of a chap starting a ruddy car.
Best to film this in case you get sucked up a car wheel arch and run over. :banana-wrench:
derek badger
Welded up the frame today, argon/5% CO2 is so much nicer to use than pure CO2. Bearings all bolted down and chains on. Fitted some adjustable feet to the bottom and then gave it a spin up with the angle grinder. Fucking scary thing. Chain guards and brackets for the grinder next.
Keep yer bits well away from those moving parts laddie. :shock:
derek badger
Skub wrote: Mon Jun 07, 2021 4:18 pm Keep yer bits well away from those moving parts laddie. :shock:
No need to book a vasectomy...
derek badger wrote: Mon Jun 07, 2021 4:34 pm
It'll be Delilah Badger before you can blink. :o
Has thanked: 20863 times
Been thanked: 13684 times
Nice welds! :thumbup:
derek badger
Made a small start on the chain guards today.
They need to be two parts. The back bolted to the frame and the front bolted to the back.
Has thanked: 8043 times
Been thanked: 5695 times
The suspense is too much!
What happened next? :!:
This is taking as long as Dazzlers Trumpet!
Nice copper plated threads on those clamps though. :thumbsup:
Does Badger work at Ritebike per chance?
