DIY roller starter
- Been thanked: 7529 times
- derek badger
- Has thanked: 769 times
- Been thanked: 1135 times
- derek badger
Re: DIY roller starter
They don't have to, but it's better if they are both driven.KungFooBob wrote: ↑Thu May 20, 2021 3:19 pm Do both rollers need to be driven, or is it just belt and braces?
- Has thanked: 836 times
- Been thanked: 1238 times
Won't the back roller try to lift the back wheel up? I have no experience of these, just tend to look at stuff and work out how it is most likely to kill me.derek badger wrote: ↑Thu May 20, 2021 3:43 pmThey don't have to, but it's better if they are both driven.KungFooBob wrote: ↑Thu May 20, 2021 3:19 pm Do both rollers need to be driven, or is it just belt and braces?
- derek badger
I've seen more twin drive starters than single ones so they must be okay. I'll make sure to film the first run though.Mussels wrote: ↑Thu May 20, 2021 4:44 pmWon't the back roller try to lift the back wheel up? I have no experience of these, just tend to look at stuff and work out how it is most likely to kill me.derek badger wrote: ↑Thu May 20, 2021 3:43 pmThey don't have to, but it's better if they are both driven.KungFooBob wrote: ↑Thu May 20, 2021 3:19 pm Do both rollers need to be driven, or is it just belt and braces?
- derek badger
- Has thanked: 1264 times
- Been thanked: 1188 times
- derek badger
Yea, I had to send the hound out to pick up some Argon/5% CO2 gas. I've got a day off work coming up soon so I'll make a start on the welding then.
I was just thinking, I wonder if you could wrap a rope around the tyre and pull start it. Of course, there's a video of a chap starting a ruddy car.
Best to film this in case you get sucked up a car wheel arch and run over.
- derek badger
Welded up the frame today, argon/5% CO2 is so much nicer to use than pure CO2. Bearings all bolted down and chains on. Fitted some adjustable feet to the bottom and then gave it a spin up with the angle grinder. Fucking scary thing. Chain guards and brackets for the grinder next.
- Has thanked: 9827 times
- Been thanked: 10145 times
Keep yer bits well away from those moving parts laddie.
- derek badger
It'll be Delilah Badger before you can blink.
- Has thanked: 15954 times
- Been thanked: 10245 times
- derek badger
Made a small start on the chain guards today.
They need to be two parts. The back bolted to the frame and the front bolted to the back.
- Has thanked: 6376 times
- Been thanked: 4753 times
- Has thanked: 2551 times
- Been thanked: 6244 times
