But what about the blokes?
New riding kit, what have you bought lately and why?
- Has thanked: 1059 times
- Been thanked: 1642 times
- Has thanked: 7575 times
- Been thanked: 5909 times
I kept the panniers on when trundling around there.weeksy wrote: Mon Apr 26, 2021 12:31 pmWhere do you propose we carry things then ?Horse wrote: Mon Apr 26, 2021 12:16 pmSupermofo wrote: Mon Apr 26, 2021 11:38 ama house key in his pocket which punched it's way out through the material, I never have anything in my pockets so should be okCastle Combe Instructor wrote: Don't have anything in your pockets that you're wouldn't want a surgeon to have to cut out.
But the point still stands, doesn't it? It's down to everyone to make their own choices about what they carry, when and how.
- Has thanked: 2833 times
- Been thanked: 3484 times
A second hand one peice IXS leathers for £110, some hefty scuffing on the right hand side. The motul leather cleaner is slowly getting the worst off though.
Youngest is keen to ride pillion so he's got my old two peice stuff. That and they seem to have shrunk after not being worn for a few years, I've kept them in the loft so can only assume that the extremes in temps have caused it.
- Has thanked: 5923 times
- Been thanked: 3547 times
Didn't buy but got this from my brother for me birthday. It's very orange and I love it.
- Has thanked: 10908 times
- Been thanked: 3951 times
I've been tempted by them - any good?Potter wrote: Fri Mar 19, 2021 12:19 pm I bought a set of Lee Parks gloves because the fella in the hat on Motolegends reckons they're the business.
https://www.motolegends.com/gloves/lee- ... ellow.html
- Has thanked: 12534 times
- Been thanked: 8507 times
They look like gardening glovesPotter wrote: Fri Mar 19, 2021 12:19 pm I bought a set of Lee Parks gloves because the fella in the hat on Motolegends reckons they're the business.
Hot_Air
- Has thanked: 1454 times
- Been thanked: 288 times
Who could resist a Rukka Woolly Knitwear Dog Jacket? Unfortunately, I bought it before checking the CE certification; does anyone know its A-rating?
Shoei RYD.
Not bad for 300 quid, the only real complaint i have is that the chin vent directs air almost straight at my eyes, not quite direct, not enough to actually make the helmet unusable, but enough to be an irritant.
Hopefully I'll get used to it.
Hot_Air
It's handy for anyone trying to keep their glasses from fogging up!
I'm ready for Summer right now.
I nabbed these Keis gloves and all the connectors for almost half price and in as new condition. Be rude not to.
Given the failure of Spring to warm up around here,I'll be testing them soon. I would've done so already,but it's pissing down hailstones and everything,so laters.
I've been meaning to buy a one piece for track for a while and they're now clamping down on the two pieces i.e. zip must be full around rather than 2/3 or 3/4. I read a max of a 2" gap.
Since I already have the InMotion brain/subscription in my Ixon vest it made sense to go for a suit with the same system so I can just swap it over.
I did ponder just using the vest under a one piece but it was a faff with it riding up whilst trying to get the suit on.
Hot_Air
RST explicitly designed for In&Motion airbag
scottyuk wrote: Wed May 19, 2021 10:07 pm Since I already have the InMotion brain/subscription in my Ixon vest it made sense to go for a suit with the same system so I can just swap it over.
I've seen others buy a jacket that's bigger than usual to allow for airbag inflation. But I reckon it means a tradeoff between increased safety from the airbag versus a loss of protection from a slightly loose fit (the material could fold over and abrade more easily, armour could move in crash conditions).
Noggin wrote: Sun May 16, 2021 4:24 pm I am convinced - with zero scientific proof - that moving shoulder protectors in a loose-fitting jacket are why my shoulder break was so bad. Zero proof, but I will guarantee that the plastic 'armour' moved!!
That may be.... and given that the 'dark' visor is about half the 'darkness' of the Arai race-dark I'm used to, it might be useful for sunglasses...Hot_Air wrote: Mon May 17, 2021 9:24 amIt's handy for anyone trying to keep their glasses from fogging up!
- Has thanked: 19445 times
- Been thanked: 4939 times
Re: RST explicitly designed for In&Motion airbag
I have soft armour in my jacket now. But in the future I will wear decent fitting armour over a tshirt then put the jacket over the top. Sizing is shit for bike gear for girls and so I've always had to compromise on baggyness somewhere to allow for actually doing up the zipsHot_Air wrote: Thu May 20, 2021 9:17 amscottyuk wrote: Wed May 19, 2021 10:07 pm Since I already have the InMotion brain/subscription in my Ixon vest it made sense to go for a suit with the same system so I can just swap it over.This solution – one airbag that you can swap between different RST clobber – has got to be ideal. The RST stuff explicitly designed for the InMotion system has elastic panels in the right place to let the airbag inflate properly. My 'Tech-Air compatible' jacket is similar, and it means I can wear an excellent fitting jacket, with the confidence that the airbag can inflate fully, yet the armour can't move out of place.
I've seen others buy a jacket that's bigger than usual to allow for airbag inflation. But I reckon it means a tradeoff between increased safety from the airbag versus a loss of protection from a slightly loose fit (the material could fold over and abrade more easily, armour could move in crash conditions).Noggin wrote: Sun May 16, 2021 4:24 pm I am convinced - with zero scientific proof - that moving shoulder protectors in a loose-fitting jacket are why my shoulder break was so bad. Zero proof, but I will guarantee that the plastic 'armour' moved!!
Hot_Air
@Noggin It took me years to save up for made-to-measure gear, but it was worth every penny.
A cheaper option is ‘adjusted to fit’ via someone like Hideout or Nine Lives. In the past, they have done a stonking job of altering off-the-peg clothing to fit me 100% perfectly (including changing armour placement). It was almost as good as made-to-measure.
- Has thanked: 602 times
- Been thanked: 4527 times
Pair of Hood jeans delivered yesterday
Sadly a bit far for me!! A friend has recommended a place relatively near (Italy, so just over the border!) but I need to earn a lot of money first!!Hot_Air wrote: Thu May 20, 2021 4:15 pm @Noggin It took me years to save up for made-to-measure gear, but it was worth every penny.
Hot_Air
I bet you have better weather! It’s May and rainy in Blighty
Not really at the mo
