- derek badger
- Has thanked: 799 times
- Been thanked: 1135 times
- Has thanked: 9682 times
- Been thanked: 9702 times
Yay!
All those sparks have been waiting over a decade just to get out,like a tadpole from a bustin' full ballbag.
- derek badger
That's a mental image I really am going to have to power-drink though to remove...
- derek badger
- Has thanked: 5503 times
- Been thanked: 12760 times
That looks a hoot. Even if it rides shit i bet it'll be fun doing it.
- derek badger
It'll be fun for a 45min blat on back roads I reckon. After that it'll rattle apart, run out of premix or I'll have to come home and change my pants...
- Has thanked: 1326 times
- Been thanked: 1652 times
Those^.derek badger wrote: ↑Thu Jan 21, 2021 6:11 pmIt'll be fun for a 45min blat on back roads I reckon. After that it'll rattle apart, run out of premix or I'll have to come home and change my pants...
Quite honestly the best thing to have which would enhance enjoyment of it would be a van to carry it over the boring roads, park up somewhere quiet (well quiet for a while anyway) warm the bike up while someone else comes along on a bike.
You might not beat em but trying will be highly entertaining.
- derek badger
I'm lucky to have some nice B roads in my doorstep, not quite as nice as up your way though.demographic wrote: ↑Thu Jan 21, 2021 7:35 pmThose^.derek badger wrote: ↑Thu Jan 21, 2021 6:11 pmIt'll be fun for a 45min blat on back roads I reckon. After that it'll rattle apart, run out of premix or I'll have to come home and change my pants...
Problem is they're not quite on my doorstep.
If I lived where I was when I was a kid it would be bloody tops.
- derek badger
For some reason I thought you were out Aspatria/Cockermouth way.demographic wrote: ↑Thu Jan 21, 2021 8:41 pm Problem is they're not quite on my doorstep.
Naah, Carlisle.derek badger wrote: ↑Thu Jan 21, 2021 8:46 pmFor some reason I thought you were out Aspatria/Cockermouth way.demographic wrote: ↑Thu Jan 21, 2021 8:41 pm Problem is they're not quite on my doorstep.
I'm often working out that way, or anywhere else in the county for that matter and a bit of Southwest Scotland as well.
Cockermouth would be ideal for it, quickly into the twisties.
- Potter
- Has thanked: 2216 times
- Been thanked: 4611 times
That's proper!
It's got late 80's Performance Bikes hooligan written all over it.
Post the pictures from A&E after your first ride
- derek badger
Funnily enough the late John Robinson's CR500 is the main inspiration behind the look I'm after.
I remember that, sculpted seat so it had a slightly lower centre of gravity, Dymag wheels and it might even have had one rad removed.
It was basically setup for hillclimb sprints.
I'll fire up a few of my Barbon CR and KX 500 pics when I get the time.
One other thing to watch out for is the kicksaltart lever wearing, then it over rotates and yer foot slips off while yer trying to start it. Most unpleasant.
I put the choke on, ease it just past compression, then let the kickstart go back to the top and then kick with gusto.
Also I don't touch the throttle til it starts or I'm just letting more air in to compress whilst slowing its flow through the carb.
- Has thanked: 15606 times
- Been thanked: 9849 times
Doesn't pump the same volume when kicking over and opening the throttle just changes the a/f ratio?
- derek badger
Cheers mate!demographic wrote: ↑Fri Jan 22, 2021 7:54 am I remember that, sculpted seat so it had a slightly lower centre of gravity, Dymag wheels and it might even have had one rad removed.
- derek badger
Found some old photos I downloaded about 15 years ago. It's an '85 conversion and this is kinda what I'm going for, I want it to look quite period rather than a full-on modern conversion.
- derek badger
New SBK bearings fitted to both wheels, just need the top hats for the rear to sort the alignment out but the chain run doesn't look to bad.
Found an old jack up stand in the shed. I'll replace the top with some MDF and see what I can do about attempting to start it.
- derek badger
New top fitted to old stand. Stainless countersink bolts and a bit of carpet tile to finish it off.
- derek badger
Went and got 10l of fuel and knocked up some 32:1 premix. Well, it wasn't first kick but it fired up on about the 3rd or 4th once I'd remembered the knack. The carb needs to come off for a clean/rebuild but fuck my old boots...IT LIVES!!!!
