derek badger
Has thanked: 1091 times
Been thanked: 1753 times
Post by derek badger »
Been thanked: 15498 times
That looks a hoot. Even if it rides shit i bet it'll be fun doing it.
derek badger
weeksy wrote: Thu Jan 21, 2021 5:50 pm That looks a hoot. Even if it rides shit i bet it'll be fun doing it.
It'll be fun for a 45min blat on back roads I reckon. After that it'll rattle apart, run out of premix or I'll have to come home and change my pants...
Has thanked: 1059 times
Been thanked: 1646 times
derek badger wrote: Thu Jan 21, 2021 6:11 pm
Those^.
Quite honestly the best thing to have which would enhance enjoyment of it would be a van to carry it over the boring roads, park up somewhere quiet (well quiet for a while anyway) warm the bike up while someone else comes along on a bike.
You might not beat em but trying will be highly entertaining.
derek badger
demographic wrote: Thu Jan 21, 2021 7:35 pm
Those^.
I'm lucky to have some nice B roads in my doorstep, not quite as nice as up your way though.
Problem is they're not quite on my doorstep.
If I lived where I was when I was a kid it would be bloody tops.
derek badger
demographic wrote: Thu Jan 21, 2021 8:41 pm Problem is they're not quite on my doorstep.
For some reason I thought you were out Aspatria/Cockermouth way.
derek badger wrote: Thu Jan 21, 2021 8:46 pm
Naah, Carlisle.
I'm often working out that way, or anywhere else in the county for that matter and a bit of Southwest Scotland as well.
Cockermouth would be ideal for it, quickly into the twisties.
derek badger
Potter wrote: Fri Jan 22, 2021 4:24 am
derek badger wrote: Thu Jan 21, 2021 5:37 pm Image
That's proper!
It's got late 80's Performance Bikes hooligan written all over it.
Post the pictures from A&E after your first ride :thumbup:
Funnily enough the late John Robinson's CR500 is the main inspiration behind the look I'm after.
I remember that, sculpted seat so it had a slightly lower centre of gravity, Dymag wheels and it might even have had one rad removed.
It was basically setup for hillclimb sprints.
I'll fire up a few of my Barbon CR and KX 500 pics when I get the time.
One other thing to watch out for is the kicksaltart lever wearing, then it over rotates and yer foot slips off while yer trying to start it. Most unpleasant.
I put the choke on, ease it just past compression, then let the kickstart go back to the top and then kick with gusto.
Also I don't touch the throttle til it starts or I'm just letting more air in to compress whilst slowing its flow through the carb.
Has thanked: 20876 times
Been thanked: 13695 times
Doesn't pump the same volume when kicking over and opening the throttle just changes the a/f ratio?
derek badger
demographic wrote: Fri Jan 22, 2021 7:54 am I remember that, sculpted seat so it had a slightly lower centre of gravity, Dymag wheels and it might even have had one rad removed.
Cheers mate! :thumbup:
derek badger
Found some old photos I downloaded about 15 years ago. It's an '85 conversion and this is kinda what I'm going for, I want it to look quite period rather than a full-on modern conversion.
derek badger
New SBK bearings fitted to both wheels, just need the top hats for the rear to sort the alignment out but the chain run doesn't look to bad.
Found an old jack up stand in the shed. I'll replace the top with some MDF and see what I can do about attempting to start it.
derek badger
New top fitted to old stand. Stainless countersink bolts and a bit of carpet tile to finish it off.
derek badger
Went and got 10l of fuel and knocked up some 32:1 premix. Well, it wasn't first kick but it fired up on about the 3rd or 4th once I'd remembered the knack. The carb needs to come off for a clean/rebuild but fuck my old boots...IT LIVES!!!! 👍👍👍
Fireworks! :banana-wrench:
derek badger
Skub wrote: Sat Jan 23, 2021 3:39 pm Fireworks! :banana-wrench:
Ring a fucking ding ding!👍
derek badger wrote: Sat Jan 23, 2021 3:13 pm Went and got 10l of fuel and knocked up some 32:1 premix. Well, it wasn't first kick but it fired up on about the 3rd or 4th once I'd remembered the knack. The carb needs to come off for a clean/rebuild but fuck my old boots...IT LIVES!!!! 👍👍👍
Fooking aces! Well done! :thumbup:
:banana-wrench: :banana-wrench: :banana-wrench: :banana-wrench: :banana-wrench: :banana-wrench: :banana-wrench:
I can't remember what carb the older KXs have, mines got the standard Keihin PWK39 D shaped slide but does yours have a PJ carb?
On about bits that break theres stuff on Youtube about the gusset kit that adresses some of the parts of the frame that break. It's aimed at the 88-2004 frames but still gives a good insight into what issues they have.
Realistically the main issue for mere mortals is the the expansion chamber bracket behind the coil.
Also Sandblaster and KX Guru have done some good Youtube vids.
They all break eventually.
