'83 GPz750-A1 malarkey.
Has thanked: 2222 times
Been thanked: 2593 times
Re: '83 GPz750-A1 malarkey.
Visited the GPz, mate wasn't there but the bike was outside.. :think: so I pulled a sneaky ;) removed the three brake calipers & the m/c from the bars :hmmm: then left before he got back. :shhh:
Fresh pile of crap to overhaul/IRAN.
That front m/c might be toast, but will assess after it comes apart.
Arsebiscuits. The difference is in the lower fork legs....
But! I did find EBC 270mm front rotors for $170 each. Haven't bitten that bullet yet
Need to have a major garage tidy up/sort out tomorrow & then finish assembling the carb rack. Found an errant float needle laying on the garage floor this evening. :wtf: It had better be from the spare rack (which was laying on the floor with the bowls & floats removed a few days ago). I'll check the spare rack tomorrow. FFS
Has thanked: 10836 times
Been thanked: 3916 times
ZRX61 wrote: Wed Jun 24, 2026 6:20 am Arsebiscuits. The difference is in the lower fork legs....
Ice cream tubs FTW.
Initial soak in Evaporust didn't seem to be doing the job, so decided to pop the sender unit apart... :shock: :wtf:
ARRGGHH!!
It's now in the small ultrasonic with water, SG-HD & some Evaporust
Has thanked: 2536 times
Been thanked: 4122 times
There'll be some serious weight reduction on that sender unit compared to OE.
mangocrazy wrote: Wed Jun 24, 2026 6:17 pm There'll be some serious weight reduction on that sender unit compared to OE.
It might even work :)
WooT!! Carb rack assembled... Tres spiffique
Still need to soda blast the throttle cable guide doodad (so it will come off again), fit the air screws & install the choke rod & associated gubbins.
