2CV6 Project Thread
Has thanked: 1183 times
Been thanked: 2277 times
Re: 2CV6 Project Thread
mangocrazy wrote: Thu Apr 24, 2025 8:20 pm Those prices look excessively reasonable to me. Beware of getting your arm bitten off...
If it means I get rid of the bits I don't need quickly then that sounds good to me. I hate the process of selling stuff. If one person offered to turn up and take the lot away in a van for a low ball offer I'd bite *their* arm off.
Getting there…
More progress.
The next move requires some care.
That was a mission. Next step cleaning, painting, fitting the adapter plate and clutch. Then to start stripping the 2cv down.
rodbargee
Has thanked: 397 times
Been thanked: 1114 times
Post by rodbargee »
we got a full weight upwrite piano in the back by taking off the roof and the rear mount for it and the boot lid drove over the M62 to Manchester. twas a hoot
More work done over the last few days. First images are the removal of the bmw clutch and flywheel...
IMG_8673 (Large).jpg (488.74 KiB) Viewed 1751 times
IMG_8674 (Large).jpg (476.7 KiB) Viewed 1751 times
IMG_8675 (Large).jpg (499.99 KiB) Viewed 1751 times
Then the gearbox adapter, crank adapter, modified 2cv flywheel and 2cv clutch are fitted...
IMG_8677 (Large).jpg (488.72 KiB) Viewed 1750 times
IMG_8678 (Large).jpg (429.08 KiB) Viewed 1750 times
IMG_8679 (Large).jpg (461.4 KiB) Viewed 1750 times
Start to remove some bodywork to give better access...
IMG_8681 (Large).jpg (434.17 KiB) Viewed 1749 times
IMG_8682 (Large).jpg (499.24 KiB) Viewed 1749 times
IMG_8687 (Large).jpg (496.63 KiB) Viewed 1749 times
Finally for today some other bits are removed. Next step is to pull the engine. The gearbox has to come out for a small modification too.
IMG_8688 (Large).jpg (499.46 KiB) Viewed 1747 times
IMG_8691 (Large).jpg (479.94 KiB) Viewed 1747 times
IMG_8692 (Large).jpg (519.42 KiB) Viewed 1747 times
Has thanked: 10959 times
Been thanked: 3995 times
Do you keep the fan?
Good work, really looking forward to the end result!
Rockburner wrote: Wed Jul 09, 2025 8:14 am Do you keep the fan?
No. The fan connects directly to the crank on the 2cv engine. The bmw engine has an external oil cooler which may have to be enlarged and fitted with electric fans, we’ll see.
Cheers.
dern wrote: Wed Jul 09, 2025 9:21 am
Cheers.
Ah - ok. Given that the engine is partially air-cooled (as designed) are you going to look into any other means of feeding air over the barrels?, or do you think the air-flow through the grill will be sufficient?
Are you keeping the BMW alternator (I'd guess you might be?) I hope it's height (on top of the cases) doesn't interfere with the bonnet, mind you - it looks like the engine is pretty low in the chassis so is that actually an issue?
I think that more air will flow over the barrels in the car than in the bike but I can make some ducts if that’s not the case.
The alternator will fit and takes up the space where the fan/carb would be.
Dry run fitting the gearbox to the engine and the engine bay ready to accept them both.
I have to pause now while I wait for a part for the gearbox that's broken. Next step is to get the engine and gearbox in place in the car so I can make some engine mounts and start to plan the exhaust.
Chassis looks in good nick, is it a replacement galvo one?
KungFooBob wrote: Sat Jul 12, 2025 11:51 am Chassis looks in good nick, is it a replacement galvo one?
Yes. Also helped by the oil leak.
Zimbo
Has thanked: 101 times
Been thanked: 158 times
Post by Zimbo »
What an excellent project, looking forward to seeing it go!
Buckaroo
Has thanked: 1048 times
Been thanked: 1108 times
Post by Buckaroo »
As we previously owned a red and white, plus green and white 2CV dolly. I'm really interested and excited to see how this goes. I won't mention it to my wife; she'd want one again. Cracking little cars.
Buckaroo wrote: Tue Jul 15, 2025 10:52 am As we previously owned a red and white, plus green and white 2CV dolly. I'm really interested and excited to see how this goes. I won't mention it to my wife; she'd want one again. Cracking little cars.
Was it this one :)
Has thanked: 3644 times
Been thanked: 2502 times
Will you be fitting an oil temp gauge? Loving this project and a "car" mate a work is interested as well.
