1 coarse, 1 fine for sharpening edges.
Tool purchases
- Has thanked: 778 times
- Been thanked: 3216 times
- Has thanked: 12606 times
- Been thanked: 8536 times
Re: Tool purchases
I just use it to grind. Nothing subtle here
- Been thanked: 2727 times
- Felix
- Has thanked: 714 times
- Been thanked: 2039 times
Re: Tool purchases
It does say in the advert "2 pre-mounted 75mm diameter and 20mm wide discs (1 grinding disc, 1 polishing disc)
- Been thanked: 9495 times
Re: Tool purchases
I need to post a correction, it's does have pre-drilled mounting holes. I need to go to spec savers.
- Has thanked: 8035 times
- Been thanked: 5694 times
- Has thanked: 10959 times
- Been thanked: 3995 times
Re: Tool purchases
Presumably pre-tapped holes in cast lugs in the base? (I bet they're Cycle thread..... )KungFooBob wrote: Tue Aug 06, 2024 6:08 am I need to post a correction, it's does have pre-drilled mounting holes. I need to go to spec savers.
- Has thanked: 2289 times
- Been thanked: 2673 times
Re: Tool purchases
For the same reason you don't put a fine edge on a wood chisel with a concrete paver.
- dern
- Has thanked: 1183 times
- Been thanked: 2277 times
Re: Tool purchases
I've only played with this for 5 minutes but this is my new favourite tool...
It's a milwaukee cordless m12 portable bandsaw. Definitely didn't need it as I have a hacksaw but it cuts through steel and aluminium like butter. It cut that steel box section in a couple of seconds. Very pleased indeed and will definitely make cutting metal less painful (arthritis in fingers).
I've a few M12 milwaukee tools now and very impressed with all of them.
- Druid
- Has thanked: 351 times
- Been thanked: 1106 times
Re: Tool purchases
Look what you made me doCount Steer wrote: Mon Aug 05, 2024 2:29 pm If anyone else wants a £25 bench grinder (should be £50)....I've got one and it's fine.
https://www.screwfix.com/p/titan-ttb905 ... 240v/549vv
- Has thanked: 316 times
- Been thanked: 1078 times
Re: Tool purchases
My nephew, apprentice electrician, loves his M12 kit, the cut off saw and heated jacket are particularly good. He barely picks his M18 kit up these days as the M12 is as capable as the higher voltage kit whilst being much lighter for all day use.dern wrote: Tue Aug 06, 2024 5:15 pm I've only played with this for 5 minutes but this is my new favourite tool...
- Has thanked: 1059 times
- Been thanked: 1646 times
Re: Tool purchases
Cordless 1/2" router...
Oh, were you expecting it to be battery powered? It's definitely cordless though.
Re: Tool purchases
One of those came up in a video I watched yesterday.
Don't fret if you can't watch all of it, he / his style is an acquired taste
Re: Tool purchases
Watched it the other day, interesting build (although after watching three versions of the tambour door I ran out of time and went to work) with some amazing details.MrLongbeard wrote: Tue Aug 27, 2024 11:07 pm One of those came up in a video I watched yesterday.
I could get bored with hin chuntering on about tattoos mind.
Re: Tool purchases
Not "purchases", per se..... but on Sunday I picked up a few things from my Dad's old workshop....
These Draper socket sets were always in disarray when my Dad was working on something... but even after what must be at least 40 years now... there's only 3 sockets missing from the 3/8" set! (the 9,12,14 mm sockets and a couple of extensions)
The 1/2" set is complete.
A load of taps and dies : mostly imperial, but there were a few metrics as well
And this:
it weighs a metric fuckton.... empty!
This is probably why:
The only reason I grabbed it is because the missus wants it for her leatherworking tools.
And this:
- Has thanked: 2556 times
- Been thanked: 4167 times
Re: Tool purchases
Ordered a pair of Knipex Pliers/Wrenches in 150mm and 250mm sizes. These are the 150mm ones:
https://toolstoredirect.co.uk/products/knipex-86-05-150
Re: Tool purchases
https://www.ebay.com/itm/235686627496?_ ... R7qsmt3fZARockburner wrote: Tue Nov 05, 2024 10:05 am Not "purchases", per se..... but on Sunday I picked up a few things from my Dad's old workshop....
https://www.ebay.com/itm/332838377989?_ ... R7ysmt3fZA
https://www.ebay.com/itm/335521029305?_ ... R76smt3fZA
Re: Tool purchases
Yeah, i could. But I've got plenty of 3/8s stuff already.ZRX61 wrote: Tue Nov 05, 2024 7:36 pmhttps://www.ebay.com/itm/235686627496?_ ... R7qsmt3fZARockburner wrote: Tue Nov 05, 2024 10:05 am Not "purchases", per se..... but on Sunday I picked up a few things from my Dad's old workshop....
In fact, it's quite possible that i have those very sockets somewhere in my toolboxes already.
Sadlonelygit
- Has thanked: 94 times
- Been thanked: 796 times
Re: Tool purchases
Anyone bought a cheap cordless impact gun off ebay.
I'm away from my windy tools and have some heavy duty nutting to undo!
Looking for any recommendations >£40
