Tool purchases
Has thanked: 599 times
Been thanked: 2448 times
Re: Tool purchases
Yorick wrote: Mon Aug 05, 2024 2:36 pm I can't see why you'd need 2 grinding discs
1 coarse, 1 fine for sharpening edges.
Has thanked: 10271 times
Been thanked: 6887 times
Re: Tool purchases
MrLongbeard wrote: Mon Aug 05, 2024 2:40 pm
I just use it to grind. Nothing subtle here :obscene-birdiedoublered:
Been thanked: 2618 times
Re: Tool purchases
See my post back up there as to why I have more than one grinder.
Has thanked: 485 times
Been thanked: 1428 times
Re: Tool purchases
It does say in the advert "2 pre-mounted 75mm diameter and 20mm wide discs (1 grinding disc, 1 polishing disc)
Been thanked: 7535 times
Re: Tool purchases
I need to post a correction, it's does have pre-drilled mounting holes. I need to go to spec savers.
Has thanked: 6381 times
Been thanked: 4761 times
Re: Tool purchases
Poor obs. :D
Has thanked: 7819 times
Been thanked: 2530 times
Re: Tool purchases
KungFooBob wrote: Tue Aug 06, 2024 6:08 am I need to post a correction, it's does have pre-drilled mounting holes. I need to go to spec savers.
Presumably pre-tapped holes in cast lugs in the base? (I bet they're Cycle thread..... )
Has thanked: 1508 times
Been thanked: 1415 times
Re: Tool purchases
Yorick wrote: Mon Aug 05, 2024 2:36 pm I can't see why you'd need 2 grinding discs.
For the same reason you don't put a fine edge on a wood chisel with a concrete paver. :roll:
Re: Tool purchases
ZRX61 wrote: Tue Aug 06, 2024 4:46 pm
Eh?
Has thanked: 1016 times
Been thanked: 1776 times
Re: Tool purchases
I've only played with this for 5 minutes but this is my new favourite tool...
It's a milwaukee cordless m12 portable bandsaw. Definitely didn't need it as I have a hacksaw but it cuts through steel and aluminium like butter. It cut that steel box section in a couple of seconds. Very pleased indeed and will definitely make cutting metal less painful (arthritis in fingers).
I've a few M12 milwaukee tools now and very impressed with all of them.
Druid
Has thanked: 276 times
Been thanked: 900 times
Re: Tool purchases
Post by Druid »
Count Steer wrote: Mon Aug 05, 2024 2:29 pm If anyone else wants a £25 bench grinder (should be £50)....I've got one and it's fine.
https://www.screwfix.com/p/titan-ttb905 ... 240v/549vv
Look what you made me do
:thumbup:
Has thanked: 145 times
Been thanked: 497 times
Re: Tool purchases
Post by Silly Car »
dern wrote: Tue Aug 06, 2024 5:15 pm I've only played with this for 5 minutes but this is my new favourite tool...
My nephew, apprentice electrician, loves his M12 kit, the cut off saw and heated jacket are particularly good. He barely picks his M18 kit up these days as the M12 is as capable as the higher voltage kit whilst being much lighter for all day use.
Has thanked: 1349 times
Been thanked: 1723 times
Re: Tool purchases
Cordless 1/2" router...
Oh, were you expecting it to be battery powered? It's definitely cordless though.
Re: Tool purchases
One of those came up in a video I watched yesterday.
Don't fret if you can't watch all of it, he / his style is an acquired taste
Re: Tool purchases
MrLongbeard wrote: Tue Aug 27, 2024 11:07 pm One of those came up in a video I watched yesterday.
Watched it the other day, interesting build (although after watching three versions of the tambour door I ran out of time and went to work) with some amazing details.
I could get bored with hin chuntering on about tattoos mind.
Re: Tool purchases
Not "purchases", per se..... but on Sunday I picked up a few things from my Dad's old workshop....
These Draper socket sets were always in disarray when my Dad was working on something... but even after what must be at least 40 years now... there's only 3 sockets missing from the 3/8" set! (the 9,12,14 mm sockets and a couple of extensions)
The 1/2" set is complete.
A load of taps and dies : mostly imperial, but there were a few metrics as well
And this:
it weighs a metric fuckton.... empty!
This is probably why:
The only reason I grabbed it is because the missus wants it for her leatherworking tools. :D
Has thanked: 2407 times
Been thanked: 3635 times
Re: Tool purchases
Ordered a pair of Knipex Pliers/Wrenches in 150mm and 250mm sizes. These are the 150mm ones:
https://toolstoredirect.co.uk/products/knipex-86-05-150
Re: Tool purchases
Rockburner wrote: Tue Nov 05, 2024 10:05 am Not "purchases", per se..... but on Sunday I picked up a few things from my Dad's old workshop....
https://www.ebay.com/itm/235686627496?_ ... R7qsmt3fZA
https://www.ebay.com/itm/332838377989?_ ... R7ysmt3fZA
https://www.ebay.com/itm/335521029305?_ ... R76smt3fZA
Re: Tool purchases
ZRX61 wrote: Tue Nov 05, 2024 7:36 pm
Yeah, i could. But I've got plenty of 3/8s stuff already. :D
In fact, it's quite possible that i have those very sockets somewhere in my toolboxes already. :D
