Things that young'uns don't understand
Demannu
- Has thanked: 65 times
- Been thanked: 1234 times
Like 2t owners checking the weather forecast in winter and guessing what jets they'll use today!
- DefTrap
- Has thanked: 1838 times
- Been thanked: 1468 times
Re: Things that young'uns don't understand
To be honest I always found my normally aspirated 4 strokes always seemed to run better on the cold, crisp morning run to work in Winter. (my fingers & gonads, not so much).
Not that I ride in the early morning any more, certainly not if it's cold FFS. So, on reflection, maybe my 'summer jetting' is and continues to be wonky.
- Has thanked: 8048 times
- Been thanked: 5698 times
My 2T certainly ran better when there was some moisture in the air. Not exactly steam injection but I think the science backs it up.
- Been thanked: 14171 times
A mate used to have a barometer in his race van to give him an idea of jetting on the day.
- Has thanked: 4088 times
- Been thanked: 2513 times
The Isle of Man TT 2 stroke jetting dilema,Sulby straight or the Mountain..
- Has thanked: 602 times
- Been thanked: 4529 times
I've never had a road 2 stroke that was that fickle, even the race ones it's a tiny difference between it being spot on and a little rich, the trouble with running spot on was that it didn't take much for it to go from spot on to lean, and lean means holed pistons, so I always ran a bit rich, I do the same with 4 strokes, not that an 8 valve 1170 that only revs to 9000rpm is especially fussy about jetting (it's more fussy about ignition timing)
- Has thanked: 2558 times
- Been thanked: 4169 times
The vital role of blue Rizlas in setting contact breaker gaps...
A bunch of us got hold of a micrometer and checked whose thumbnail was nearest 25thou for setting plug gaps.
- Cousin Jack
- Has thanked: 3016 times
- Been thanked: 2529 times
The art of kickstarting a single.
And the pain of getting it wrong.
- Has thanked: 10971 times
- Been thanked: 4004 times
Especially a left-foot kick-start (eg MZ).Cousin Jack wrote: Tue Jan 09, 2024 1:18 pm The art of kickstarting a single.
- Been thanked: 9505 times
But theres fuck all kick back/compression on an a two stroke MZ, I could start my 301 by rocking it backward then forward in gear.
It was more the fact that the pilion peg was sited to catch your ankle bone as you kicked.... My dad was very pissed off about the hole I tore in his boots... (trying to start it in trainers was not going to happen).KungFooBob wrote: Tue Jan 09, 2024 2:00 pm But theres fuck all kick back/compression on an a two stroke MZ, I could start my 301 by rocking it backward then forward in gear.
- Has thanked: 7636 times
- Been thanked: 5937 times
No no no! You need to go electronic - much easier.mangocrazy wrote: Tue Jan 09, 2024 12:51 pm The vital role of blue Rizlas in setting contact breaker gaps...
Tune a transistor radio to between stations static.
Ignition on. Gradually turn the crank. You'll hear a 'pop' when the points open. Check it coincides with the markers.
Easy!
I made up a little battery-powered device with a 9v bulb in circuit and a couple of small croc clips. When the light went out the points had opened.Horse wrote: Tue Jan 09, 2024 2:03 pmNo no no! You need to go electronic - much easier.mangocrazy wrote: Tue Jan 09, 2024 12:51 pm The vital role of blue Rizlas in setting contact breaker gaps...
Easy!
I was sick of the Rizlas getting wet and turning into Rizla-shaped decorations, plus it was more sensitive/accurate.
- Has thanked: 245 times
- Been thanked: 1228 times
- Contact:
It was also easy to clip a bulb across the moving point and the casing and switch the ignition on. Then the bulb lit up when the points opened.mangocrazy wrote: Tue Jan 09, 2024 2:06 pmI made up a little battery-powered device with a 9v bulb in circuit and a couple of small croc clips. When the light went out the points had opened.Horse wrote: Tue Jan 09, 2024 2:03 pmNo no no! You need to go electronic - much easier.mangocrazy wrote: Tue Jan 09, 2024 12:51 pm The vital role of blue Rizlas in setting contact breaker gaps...
Easy!
- Contact:
I never raced, but I remember the TZ350 sidecar guys saying that if they got past Ballacraine on the first lap, they had hopes of finishing the race.Bustaspoke wrote: Tue Jan 09, 2024 11:27 am The Isle of Man TT 2 stroke jetting dilema,Sulby straight or the Mountain..
Demannu
Or EMP or Thursday afternoonBustaspoke wrote: Tue Jan 09, 2024 11:27 am The Isle of Man TT 2 stroke jetting dilema,Sulby straight or the Mountain..
It was alway mountain jetting for me btw, better to be 500rpm shy than seized at the 33rd
Very boring listening to a disconnected light bulb the rest of the time.
- Contact:
I’m rubbish on a bike, but I’m pretty good at getting kicked back without getting hurt or falling in the gutter. Takes practice!Cousin Jack wrote: Tue Jan 09, 2024 1:18 pm The art of kickstarting a single.
In that case,when I finally get around to putting my XT600 back together you might be getting a call,it has 3 wires on the ignition pickup & from what I've read it does both the advance & retard.I know where one of the wires goes,but as the other two failed I'm not sure what way around to connect them .I think that if I get them the wrong way round I'll be getting launched over the barsJackyJoll wrote: Tue Jan 09, 2024 2:21 pmI’m rubbish on a bike, but I’m pretty good at getting kicked back without getting hurt or falling in the gutter. Takes practice!Cousin Jack wrote: Tue Jan 09, 2024 1:18 pm The art of kickstarting a single.
