Things that young'uns don't understand
Demannu
Has thanked: 65 times
Been thanked: 1234 times
Post by Demannu »
Like 2t owners checking the weather forecast in winter and guessing what jets they'll use today!
DefTrap
Has thanked: 1838 times
Been thanked: 1468 times
Re: Things that young'uns don't understand
Post by DefTrap »
To be honest I always found my normally aspirated 4 strokes always seemed to run better on the cold, crisp morning run to work in Winter. (my fingers & gonads, not so much).
Not that I ride in the early morning any more, certainly not if it's cold FFS. So, on reflection, maybe my 'summer jetting' is and continues to be wonky.
Has thanked: 8048 times
Been thanked: 5698 times
My 2T certainly ran better when there was some moisture in the air. Not exactly steam injection but I think the science backs it up.
Been thanked: 14171 times
A mate used to have a barometer in his race van to give him an idea of jetting on the day.
Has thanked: 4088 times
The Isle of Man TT 2 stroke jetting dilema,Sulby straight or the Mountain..
Been thanked: 4529 times
I've never had a road 2 stroke that was that fickle, even the race ones it's a tiny difference between it being spot on and a little rich, the trouble with running spot on was that it didn't take much for it to go from spot on to lean, and lean means holed pistons, so I always ran a bit rich, I do the same with 4 strokes, not that an 8 valve 1170 that only revs to 9000rpm is especially fussy about jetting (it's more fussy about ignition timing)
Has thanked: 2558 times
Been thanked: 4169 times
The vital role of blue Rizlas in setting contact breaker gaps...
A bunch of us got hold of a micrometer and checked whose thumbnail was nearest 25thou for setting plug gaps. :D
Has thanked: 3016 times
Been thanked: 2528 times
The art of kickstarting a single.
And the pain of getting it wrong.
Has thanked: 10971 times
Been thanked: 4004 times
Cousin Jack wrote: Tue Jan 09, 2024 1:18 pm The art of kickstarting a single.
Especially a left-foot kick-start (eg MZ).
Been thanked: 9505 times
But theres fuck all kick back/compression on an a two stroke MZ, I could start my 301 by rocking it backward then forward in gear.
KungFooBob wrote: Tue Jan 09, 2024 2:00 pm But theres fuck all kick back/compression on an a two stroke MZ, I could start my 301 by rocking it backward then forward in gear.
It was more the fact that the pilion peg was sited to catch your ankle bone as you kicked.... My dad was very pissed off about the hole I tore in his boots... (trying to start it in trainers was not going to happen).
Has thanked: 7636 times
Been thanked: 5937 times
mangocrazy wrote: Tue Jan 09, 2024 12:51 pm The vital role of blue Rizlas in setting contact breaker gaps...
No no no! You need to go electronic - much easier.
Tune a transistor radio to between stations static.
Ignition on. Gradually turn the crank. You'll hear a 'pop' when the points open. Check it coincides with the markers.
Easy!
Horse wrote: Tue Jan 09, 2024 2:03 pm
Easy!
I made up a little battery-powered device with a 9v bulb in circuit and a couple of small croc clips. When the light went out the points had opened.
I was sick of the Rizlas getting wet and turning into Rizla-shaped decorations, plus it was more sensitive/accurate.
Been thanked: 1228 times
mangocrazy wrote: Tue Jan 09, 2024 2:06 pm
Easy!
It was also easy to clip a bulb across the moving point and the casing and switch the ignition on. Then the bulb lit up when the points opened.
Bustaspoke wrote: Tue Jan 09, 2024 11:27 am The Isle of Man TT 2 stroke jetting dilema,Sulby straight or the Mountain..
I never raced, but I remember the TZ350 sidecar guys saying that if they got past Ballacraine on the first lap, they had hopes of finishing the race.
Demannu
Post by Demannu »
Or EMP or Thursday afternoon
It was alway mountain jetting for me btw, better to be 500rpm shy than seized at the 33rd
Very boring listening to a disconnected light bulb the rest of the time.
I’m rubbish on a bike, but I’m pretty good at getting kicked back without getting hurt or falling in the gutter. Takes practice!
JackyJoll wrote: Tue Jan 09, 2024 2:21 pm
In that case,when I finally get around to putting my XT600 back together you might be getting a call,it has 3 wires on the ignition pickup & from what I've read it does both the advance & retard.I know where one of the wires goes,but as the other two failed I'm not sure what way around to connect them .I think that if I get them the wrong way round I'll be getting launched over the bars :wtf:
