Ignition Coils
Beancounter
- Has thanked: 3126 times
- Been thanked: 684 times
Ignition Coils
Aprilia Caponord ETV1000 2007 (Gen 2).
It has four coils, two per cylinder, all the same. Bike appears to run fine at idle but under load bogs down quite badly. If running at idle and in the garage, it doesn't take long to get high on the petrol fumes so I guess there's unburnt fuel. One of the rear coil has a crack and you could see the spark arcing to the frame. I've tried wrapping it in rubber amalgamating tape but it's no better so I'm trying to source a reasonably priced replacements - Aprilia want £300 for a new one!
All suggested replacements (Renault Laguna V6, Clio V6 and Citreon V6) coils have a female connector on the coil whilst I need a male connector.
My questions - can the connections be swapped or adapted? I assume not. If not, could I not just swap out the HT lead for one that would fit? I've spent £130 on coils which *should* fit and am beginning to regret not phoning the Aprilia dealer to start with.
Sadlonelygit
- Has thanked: 94 times
- Been thanked: 796 times
Beancounter
Re: Ignition Coils
Thank you, haven't seen that particular page before and it explains the "woodscrew" that I'd been reading about on the Aprilia forum. I have a few that I can practice on at least.
- Has thanked: 602 times
- Been thanked: 4528 times
Re: Ignition Coils
In theory any coil of the right resistance will work, they only need the two wires connected, it doesn't matter which way round, and the HT lead to go to a spark plug.
Any HT lead will work.
Why not convert it to stick coils?
- Been thanked: 9495 times
Re: Ignition Coils
EFALe_Fromage_Grande wrote: Mon Oct 14, 2024 8:51 pm Why not have it set on fire, for a very reasonable £500 plus expenses?
Beancounter
Re: Ignition Coils
Ta. It's already on stick coils. I was wondering if getting the 'right' coil was more to do with it fitting in the space rather than delivering the spark.Le_Fromage_Grande wrote: Mon Oct 14, 2024 8:51 pm In theory any coil of the right resistance will work, they only need the two wires connected, it doesn't matter which way round, and the HT lead to go to a spark plug.
Ouch. Given it fried its reg/rec a couple of months ago it may be trying to self-immolate.KungFooBob wrote: Mon Oct 14, 2024 8:53 pmEFALe_Fromage_Grande wrote: Mon Oct 14, 2024 8:51 pm Why not have it set on fire, for a very reasonable £500 plus expenses?
- Has thanked: 10959 times
- Been thanked: 3995 times
Re: Ignition Coils
I still don't understand why you keep standing in it's way....Beancounter wrote: Tue Oct 15, 2024 10:54 am
Beancounter
Re: Ignition Coils
Because up until August this year, the bike has been faultless.Rockburner wrote: Tue Oct 15, 2024 11:19 amI still don't understand why you keep standing in it's way....Beancounter wrote: Tue Oct 15, 2024 10:54 am
- Has thanked: 2556 times
- Been thanked: 4167 times
Re: Ignition Coils
Have you thought of giving Griff Wooley at AP Workshops in Tamworth a call? I know he has used spares for Falcos, Milles, Tuonos etc. He may well know a cheaper workaround or alternative.
Re: Ignition Coils
If he has some spares or a workaround, that could save me a lot.mangocrazy wrote: Tue Oct 15, 2024 9:40 pm Have you thought of giving Griff Wooley at AP Workshops in Tamworth a call? I know he has used spares for Falcos, Milles, Tuonos etc. He may well know a cheaper workaround or alternative.
