Electrical multi connectors
iansoady
Has thanked: 59 times
Been thanked: 169 times
Post by iansoady »
Having been brought up on Lucas bullets which are simplicity themselves to dismantle - in fact have been know to do it themselves - I've always had trouble with the multi connectors found on more modern bikes - the one with a sprung barb to hold them together. Like this:
I reasoned that there must be a tool to help with this, and after some searching I found this: https://www.ebay.co.uk/itm/375506485883 ... 4438651112
It arrived this morning so I rushed out to the garage to try it. I have to report that, although not perfect - finish a bit rough - it did the job with no problems. I can recommend this tool. Obviously not something you need every day but invaluable when you do.
Has thanked: 218 times
Been thanked: 689 times
Re: Electrical multi connectors
Have you been hacked?
iansoady
Post by iansoady »
I thought the tool you showed was more hose related than electrical..
Has thanked: 261 times
Been thanked: 1265 times
iansoady wrote: Tue Jul 30, 2024 12:03 pm Having been brought up on Lucas bullets which are simplicity themselves to dismantle.
Except when they’re stuck.
roadster
Has thanked: 15 times
Been thanked: 147 times
Post by roadster »
I always use a screwdriver from one of those "Jewellers" sets. The key is to figure out where to insert it!
iansoady
Post by iansoady »
David wrote: Wed Jul 31, 2024 7:14 am I thought the tool you showed was more hose related than electrical..
No, you apply it to the connector so that one of the arms depresses the latch. Those connectors can be a nightmare leaving broken fingernails and the air blue with curses.
Roadster - the tool os to disconnect the connectors not remove the terminals from inside.
Has thanked: 599 times
Been thanked: 2428 times
It might work, but thems hose / spark plug pliers.
Proper disconnect pliers have a different head, they even show it in one of their advertising photos (top right)
But if it works for you then go with it
iansoady wrote: Wed Jul 31, 2024 10:04 am broken fingernails
I didn’t realise it could be that serious.
iansoady
Post by iansoady »
MrLongbeard wrote: Wed Jul 31, 2024 10:26 am It might work, but thems hose / spark plug pliers.
As I say, it does work for me and have used it a couple of times now. Could you let us know where the "correct" item can be got from?
All over the internet, I've never bothered as the only ones that give me grief are usually hidden away and I'd risk more damage to the wires
https://www.neilsentools.com/products/c ... j1EALw_wcB
iansoady
Post by iansoady »
Yes... That tool also raises the tab on locking push tab connectors but it's useful to have it shown.
