Scratched visor.
- the_priest
- Has thanked: 1906 times
- Been thanked: 2164 times
Re: Scratched visor.
A small dab of AutoSol may just smooth that out nicely. I've done that to remove scratches on a visor before, but remember it may also remove any coating that is on there as well...
- Has thanked: 7726 times
- Been thanked: 2401 times
I once cleaned off an iridium visor with Brasso and it was perfectly usable afterwards. Its probably the weakest abrasive out there.
- Has thanked: 5944 times
- Been thanked: 4926 times
if it's scratched anyway, so the only other alternative is a new visor, you don't really have a lot to lose.
At least, because it's tinted, you won't be using it at night so at risk of worsening headlamp glare.
- Trogladyte
- Has thanked: 68 times
- Been thanked: 89 times
I've got some plastic polish in the garage. Someone in the other place gave it to me, when I was moaning abut the boy scratching screens by throwing race bikes down the track. (Forgotten who it was, which is a bit unforgivable - thanks someone!) It does a bloody brilliant job on screens - I was amazed that a deeply scratched screen could be recovered with good optical properties, as well as cosmetics. I imagine it would work on a visor too.
- Has thanked: 300 times
- Been thanked: 541 times
I tried that on an Arai dark visor before, and ended up taking off the dark coating but only in a specific area.
I'd order another first, then try to rescue this one as a spare because it probably won't be any good after.
- Has thanked: 10113 times
- Been thanked: 6649 times
I tried Solvol as suggested on my 100% MX goggles. They're now in the bin completely wrecked
- Has thanked: 2828 times
- Been thanked: 536 times
What plastic polish are you using?Trogladyte wrote: ↑Sat Aug 29, 2020 1:06 pm I've got some plastic polish in the garage. Someone in the other place gave it to me, when I was moaning abut the boy scratching screens by throwing race bikes down the track. (Forgotten who it was, which is a bit unforgivable - thanks someone!) It does a bloody brilliant job on screens - I was amazed that a deeply scratched screen could be recovered with good optical properties, as well as cosmetics. I imagine it would work on a visor too.
- Trogladyte
Cant remember the brand. Will try to dig it out.Beancounter wrote: ↑Sun Sep 06, 2020 3:14 pmWhat plastic polish are you using?Trogladyte wrote: ↑Sat Aug 29, 2020 1:06 pm I've got some plastic polish in the garage. Someone in the other place gave it to me, when I was moaning abut the boy scratching screens by throwing race bikes down the track. (Forgotten who it was, which is a bit unforgivable - thanks someone!) It does a bloody brilliant job on screens - I was amazed that a deeply scratched screen could be recovered with good optical properties, as well as cosmetics. I imagine it would work on a visor too.
- Trogladyte
Found it.Its called Xerapol.Beancounter wrote: ↑Sun Sep 06, 2020 3:14 pmWhat plastic polish are you using?Trogladyte wrote: ↑Sat Aug 29, 2020 1:06 pm I've got some plastic polish in the garage. Someone in the other place gave it to me, when I was moaning abut the boy scratching screens by throwing race bikes down the track. (Forgotten who it was, which is a bit unforgivable - thanks someone!) It does a bloody brilliant job on screens - I was amazed that a deeply scratched screen could be recovered with good optical properties, as well as cosmetics. I imagine it would work on a visor too.
Thanks Trog, got some ordered.Trogladyte wrote: ↑Fri Sep 11, 2020 11:01 pmFound it.Its called Xerapol.Beancounter wrote: ↑Sun Sep 06, 2020 3:14 pmWhat plastic polish are you using?Trogladyte wrote: ↑Sat Aug 29, 2020 1:06 pm I've got some plastic polish in the garage. Someone in the other place gave it to me, when I was moaning abut the boy scratching screens by throwing race bikes down the track. (Forgotten who it was, which is a bit unforgivable - thanks someone!) It does a bloody brilliant job on screens - I was amazed that a deeply scratched screen could be recovered with good optical properties, as well as cosmetics. I imagine it would work on a visor too.
- Has thanked: 9678 times
- Been thanked: 9700 times
Good stuff,I've used it in the past too. Haven't ever tried it on visors though.
