Scratched visor.
- the_priest
- Has thanked: 2098 times
- Been thanked: 2558 times
Re: Scratched visor.
A small dab of AutoSol may just smooth that out nicely. I've done that to remove scratches on a visor before, but remember it may also remove any coating that is on there as well...
- Has thanked: 10964 times
- Been thanked: 3996 times
I once cleaned off an iridium visor with Brasso and it was perfectly usable afterwards. Its probably the weakest abrasive out there.
- Has thanked: 7623 times
- Been thanked: 5931 times
if it's scratched anyway, so the only other alternative is a new visor, you don't really have a lot to lose.
At least, because it's tinted, you won't be using it at night so at risk of worsening headlamp glare.
Taff
- Has thanked: 334 times
- Been thanked: 1191 times
A plastic polishing kit will come with various grades of abrasives to polish out the scratches and can bring it up as good as new, provided you have the patience to do it.
- Trogladyte
- Has thanked: 72 times
- Been thanked: 106 times
- Contact:
I've got some plastic polish in the garage. Someone in the other place gave it to me, when I was moaning abut the boy scratching screens by throwing race bikes down the track. (Forgotten who it was, which is a bit unforgivable - thanks someone!) It does a bloody brilliant job on screens - I was amazed that a deeply scratched screen could be recovered with good optical properties, as well as cosmetics. I imagine it would work on a visor too.
A_morti
- Has thanked: 412 times
- Been thanked: 824 times
I tried that on an Arai dark visor before, and ended up taking off the dark coating but only in a specific area.
I'd order another first, then try to rescue this one as a spare because it probably won't be any good after.
- Has thanked: 12609 times
- Been thanked: 8539 times
I tried Solvol as suggested on my 100% MX goggles. They're now in the bin completely wrecked
Beancounter
- Has thanked: 3130 times
- Been thanked: 684 times
What plastic polish are you using?Trogladyte wrote: Sat Aug 29, 2020 1:06 pm I've got some plastic polish in the garage. Someone in the other place gave it to me, when I was moaning abut the boy scratching screens by throwing race bikes down the track. (Forgotten who it was, which is a bit unforgivable - thanks someone!) It does a bloody brilliant job on screens - I was amazed that a deeply scratched screen could be recovered with good optical properties, as well as cosmetics. I imagine it would work on a visor too.
- Trogladyte
- Contact:
Cant remember the brand. Will try to dig it out.Beancounter wrote: Sun Sep 06, 2020 3:14 pmWhat plastic polish are you using?Trogladyte wrote: Sat Aug 29, 2020 1:06 pm I've got some plastic polish in the garage. Someone in the other place gave it to me, when I was moaning abut the boy scratching screens by throwing race bikes down the track. (Forgotten who it was, which is a bit unforgivable - thanks someone!) It does a bloody brilliant job on screens - I was amazed that a deeply scratched screen could be recovered with good optical properties, as well as cosmetics. I imagine it would work on a visor too.
- Trogladyte
- Contact:
Found it.Its called Xerapol.Beancounter wrote: Sun Sep 06, 2020 3:14 pmWhat plastic polish are you using?Trogladyte wrote: Sat Aug 29, 2020 1:06 pm I've got some plastic polish in the garage. Someone in the other place gave it to me, when I was moaning abut the boy scratching screens by throwing race bikes down the track. (Forgotten who it was, which is a bit unforgivable - thanks someone!) It does a bloody brilliant job on screens - I was amazed that a deeply scratched screen could be recovered with good optical properties, as well as cosmetics. I imagine it would work on a visor too.
Beancounter
Thanks Trog, got some ordered.Trogladyte wrote: Fri Sep 11, 2020 11:01 pmFound it.Its called Xerapol.Beancounter wrote: Sun Sep 06, 2020 3:14 pmWhat plastic polish are you using?Trogladyte wrote: Sat Aug 29, 2020 1:06 pm I've got some plastic polish in the garage. Someone in the other place gave it to me, when I was moaning abut the boy scratching screens by throwing race bikes down the track. (Forgotten who it was, which is a bit unforgivable - thanks someone!) It does a bloody brilliant job on screens - I was amazed that a deeply scratched screen could be recovered with good optical properties, as well as cosmetics. I imagine it would work on a visor too.
Good stuff,I've used it in the past too. Haven't ever tried it on visors though.
