Need to get this sucky thing off!!
Has thanked: 16240 times
Been thanked: 3938 times
:angelic-green: :angelic-green: :angelic-green:
But seriously, phone holder on the windscreen. I’m never just sticking a new one on a screen!! Well maybe if it’s my car!! But I bought it to use in different vehicles. But can’t get the bastard thing off :cry: :cry:
Any ideas? I have ‘released’ the lever but the sucky thing refuses to come off :cry: :cry: HELP!!
Bigjawa
Has thanked: 221 times
Been thanked: 879 times
Re: Need to get this sucky thing off!!
Post by Bigjawa »
Take it you've pulled the wee tab? Failing that, credit card slid under the rubber, you might have to get a bit forceful with it.
Or hot water poured on the outside of the windscreen where its attached.
Bigjawa wrote: Sun Feb 18, 2024 11:46 am Take it you've pulled the wee tab? Failing that, credit card slid under the rubber, you might have to get a bit forceful with it.
Dammit!! Forgot about heat!! 🤣🤣
I’ll have a go with a card in a bit. Being LHD it’s not so easy to get my left arm to it with any force, and at that angle the right doesn’t have any :roll:
I stupidly stuck it too low, so not only do I need to be able to transfer it to other vehicles, I can’t fit a coffee cup in the holder 😳😳😳
Has thanked: 10280 times
Been thanked: 6892 times
Reet big 'ammer :obscene-birdiedoublered:
Has thanked: 839 times
Been thanked: 1242 times
Gently pulling the little tab should let some air in and make it drop off, was there a lever you pushed to make it stick?
We must all be getting old and boring.
Back in the old days there'd have been dozens of smutty replies about the thread title.
Has thanked: 2409 times
Been thanked: 3639 times
A Stanley knife blade inserted at a 20 degree (ish) angle should slide between window glass and suction cup and break the seal.
Bigjawa
Post by Bigjawa »
mangocrazy wrote: Sun Feb 18, 2024 12:38 pm A Stanley knife blade inserted at a 20 degree (ish) angle should slide between window glass and suction cup and break the seal.
Dude, you want to let the FUF loose with a Stanley knife? 😲😲😲😲😲
It'd be carnage!
Bigjawa wrote: Sun Feb 18, 2024 12:51 pm
It'd be carnage!
Yeah, fair cop. Forget I ever mentioned it... :)
BartonBKing
Has thanked: 2 times
Been thanked: 41 times
Post by BartonBKing »
Got an airline handy? Blast a jet of air between the cup and glass, failing that, a small thin screwdriver carefully pushed in to release the vacuum.
Has thanked: 1510 times
Been thanked: 1415 times
BartonBKing wrote: Sun Feb 18, 2024 1:44 pm Got an airline handy? Blast a jet of air between the cup and glass, failing that, a needle or toothpick carefully pushed in to release the vacuum.
FTFY :)
Has thanked: 9845 times
Been thanked: 10157 times
Has Noggin lost all her fingers and suffered multiple lacerations from a freakish accident with an exploding windscreen yet? :(
Saga Lout
Has thanked: 567 times
Been thanked: 757 times
Post by Saga Lout »
Yorick wrote: Sun Feb 18, 2024 12:27 pm We must all be getting old and boring.
What's the French for double entendre?
I was waiting to see, but I am sadly disappointed!! You are all old and boring :lol: :lol: :lol:
Yorick wrote: Sun Feb 18, 2024 12:10 pm Reet big 'ammer :obscene-birdiedoublered:
Not my vehicle :( :(
Mussels wrote: Sun Feb 18, 2024 12:23 pm Gently pulling the little tab should let some air in and make it drop off, was there a lever you pushed to make it stick?
Yes to the little lever, nope to the little tab letting air out! :lol: It was proper stuck! Like sticky stuck, not just sucky stuck!!
Potter wrote: Sun Feb 18, 2024 12:30 pm Did you stick it on?
Let’s hope it wasn’t stuck on by someone using super glue.
As people have said, pull the tab or slide something in if you can to break the seal.
:lol: Yup - just lil old me! Peeled the plastic off it and stuck it to the screen!!! Not convinced it is just vacuum, so the tab doesn't break a seal as such, but the card thing worked :D :D
It'd be carnage!
It has been in the past! Luckily I didn't have one to hand :D And no shops open to stock up on dangerous implements! LOL
Anyway - your original suggestion worked, I used a couple of the work cards cos they are plastic and I didn't have anything credit card like in my purse that I could risk breaking!! :lol: :lol:
So, now I know how to get it off, I can, and I have all my fingers and no new damage to me :D :D :D
Buckaroo
Has thanked: 739 times
Been thanked: 719 times
Post by Buckaroo »
I did have my hopes raised on reading the title :obscene-birdiedoublered:
ninja
Has thanked: 65 times
Been thanked: 87 times
Post by ninja »
Usually you can't get the fucking things to stay on!
Has thanked: 2948 times
Been thanked: 1884 times
Nuke the thing from orbit, it’s the only way to be sure……
Has thanked: 487 times
Been thanked: 1431 times
All the ones i have had had a little lever you pushed to release the suction then pull that little tab. See this one says lock on the middle lever.
https://m.media-amazon.com/images/I/81j ... L1500_.jpg
Big Red
Has thanked: 3 times
Been thanked: 73 times
Post by Big Red »
dental floss
ninja wrote: Sun Feb 18, 2024 8:05 pm Usually you can't get the fucking things to stay on!
LOL I've had some like that, this one is the total opposite!! :lol: :lol:
Felix wrote: Sun Feb 18, 2024 10:00 pm All the ones i have had had a little lever you pushed to release the suction then pull that little tab. See this one says lock on the middle lever.
This has that, but the base is proper sticky. Usually the ones I've had have been plastic and rely on the suction bit to keep them in place (so a lot fall off, as above!!). This one is full on proper sticky!! :lol: :lol: Better than the falling off ones, well, now I know how to get it off the screen!! :lol: :lol: :lol:
