Cutting rectangle holes in 1.8 OSB wood
- formula400
- Has thanked: 482 times
- Been thanked: 1045 times
- Contact:
Right so I am insulting my shed, roof is done, and started the walls (yes it’s taken me this long) it one of those bit here and a bit there. Walls should be done quicker than the roof. It’s just free time.
Anyways question is, when I go and get some these sheets of wood for the walls how do I cut rectangles out of them for the light switches, plugs and windows???
Some one suggested a multitool
CBR650r
- Has thanked: 12620 times
- Been thanked: 8541 times
- Has thanked: 10971 times
- Been thanked: 4004 times
Re: Cutting rectangle holes in 1.8 OSB wood
I don't blame you, it's been slagging you off something rotten behind your back.....
formula400 wrote: Mon Jan 22, 2024 5:45 pm
As Yoz said - drill holes then use a jigsaw.
Bit more details - draw the outline of the hole you want, drill holes that are greater in diameter than the width of the jigsaw blade WITHIN that outline, then use the jigsaw to remove the rest of the material inside the outline. the only cuts that need to be "neat" are the ones that run along the outline, any other cuts where you're removing small bits of wood can be rough as you like.
- Has thanked: 8048 times
- Been thanked: 5698 times
Or, you can pull the sockets and switches off and mount them on the new interior boards if they're surface mounted types.
You can't do that with the windows, obvs.
- Been thanked: 9504 times
- Has thanked: 602 times
- Been thanked: 4529 times
- Has thanked: 7635 times
- Been thanked: 5937 times
I know it's not, but that looks like exactly the kind of wind up tool you'd send an apprentice to go and get for his drill, after they've picked up a can of tartan paint and a long weight.
...and five meters of fallopian tubing.Mr. Dazzle wrote: Tue Jan 23, 2024 8:52 am I know it's not, but that looks like exactly the kind of wind up tool you'd send an apprentice to go and get for his drill, after they've picked up a can of tartan paint and a long weight.
And some sky hooks and a bucket of steam.KungFooBob wrote: Tue Jan 23, 2024 8:58 am...and five meters of fallopian tubing.Mr. Dazzle wrote: Tue Jan 23, 2024 8:52 am I know it's not, but that looks like exactly the kind of wind up tool you'd send an apprentice to go and get for his drill, after they've picked up a can of tartan paint and a long weight.
Don't forget a spirit level bubble.Yorick wrote: Tue Jan 23, 2024 9:03 amAnd some sky hooks and a bucket of steam.KungFooBob wrote: Tue Jan 23, 2024 8:58 am...and five meters of fallopian tubing.Mr. Dazzle wrote: Tue Jan 23, 2024 8:52 am I know it's not, but that looks like exactly the kind of wind up tool you'd send an apprentice to go and get for his drill, after they've picked up a can of tartan paint and a long weight.
- Yambo
- Has thanked: 512 times
- Been thanked: 1403 times
If you've got to do a few square holes make a jig so they are all the same.
- Has thanked: 1059 times
- Been thanked: 1646 times
I've usually done like Yorick suggested and drilled holes at corners and cut it out with a jigsaw.
I now have a multitool but its fucking slow for that type of usage compared to a jigsaw.
That doesn't stop the fucking sparks from deafening every bugger on site by cutting every socket box out with a multitol though, feckless gimps.
Jeez, even a padsaw does the job.
Wooodemographic wrote: Tue Jan 23, 2024 9:03 pm I've usually done like Yorick suggested and drilled holes at corners and cut it out with a jigsaw.
That's from someone with O'level woodwork
- Has thanked: 2558 times
- Been thanked: 4168 times
When you need one, they're the only tool for the job. But using a tool that sounds like a thousand angry wasps when there's a better way should be a stabbing offence.demographic wrote: Tue Jan 23, 2024 9:03 pm That doesn't stop the fucking sparks from deafening every bugger on site by cutting every socket box out with a multitool though
- Has thanked: 222 times
- Been thanked: 788 times
IIRC it is.mangocrazy wrote: Tue Jan 23, 2024 11:24 pmWhen you need one, they're the only tool for the job. But using a tool that sounds like a thousand angry wasps when there's a better way should be a stabbing offence.demographic wrote: Tue Jan 23, 2024 9:03 pm That doesn't stop the fucking sparks from deafening every bugger on site by cutting every socket box out with a multitool though
But fun, nevertheless.
The high speed vibrating blade tools have saved me plenty of time and effort. But they are costly if you happen to hit a nail or some other hard obstruction because the blades are not very tough and are expensive.
- formula400
- Contact:
Ok cool, a few different routs to go. I already have a jigsaw and drill.
I like the box cutter, but most of what I need to cut will be rectangular.
What will give me the cleanest finish??
CBR650r
- formula400
- Contact:
[/quote]
As Yoz
[/quote]
CBR650r
