Cutting rectangle holes in 1.8 OSB wood
formula400
Has thanked: 444 times
Been thanked: 863 times
Post by formula400 »
Right so I am insulting my shed, roof is done, and started the walls (yes it’s taken me this long) it one of those bit here and a bit there. Walls should be done quicker than the roof. It’s just free time.
Anyways question is, when I go and get some these sheets of wood for the walls how do I cut rectangles out of them for the light switches, plugs and windows???
Some one suggested a multitool
CBR650r :mrgreen:
Has thanked: 10263 times
Been thanked: 6885 times
Re: Cutting rectangle holes in 1.8 OSB wood
Drill hole at each corner. Buy a cheap jigsaw.
Has thanked: 7814 times
Been thanked: 2527 times
formula400 wrote: Mon Jan 22, 2024 5:45 pm Right so I am insulting my shed,
I don't blame you, it's been slagging you off something rotten behind your back.....
As Yoz said - drill holes then use a jigsaw.
Bit more details - draw the outline of the hole you want, drill holes that are greater in diameter than the width of the jigsaw blade WITHIN that outline, then use the jigsaw to remove the rest of the material inside the outline. the only cuts that need to be "neat" are the ones that run along the outline, any other cuts where you're removing small bits of wood can be rough as you like.
Has thanked: 6376 times
Been thanked: 4751 times
Or, you can pull the sockets and switches off and mount them on the new interior boards if they're surface mounted types.
You can't do that with the windows, obvs. :lol:
Been thanked: 7526 times
Use a multi tool
Le_Fromage_Grande wrote: Mon Jan 22, 2024 6:49 pm Use a multi tool
Hammers are multi tools :obscene-birdiedoublered: :banana-dance:
Has thanked: 6187 times
Been thanked: 5087 times
Plus:
https://www.toolstation.com/smart-trade ... lsrc=aw.ds
Has thanked: 2550 times
Been thanked: 6244 times
I know it's not, but that looks like exactly the kind of wind up tool you'd send an apprentice to go and get for his drill, after they've picked up a can of tartan paint and a long weight.
Mr. Dazzle wrote: Tue Jan 23, 2024 8:52 am I know it's not, but that looks like exactly the kind of wind up tool you'd send an apprentice to go and get for his drill, after they've picked up a can of tartan paint and a long weight.
...and five meters of fallopian tubing.
KungFooBob wrote: Tue Jan 23, 2024 8:58 am
And some sky hooks and a bucket of steam.
Yorick wrote: Tue Jan 23, 2024 9:03 am
Don't forget a spirit level bubble.
Yambo
Has thanked: 598 times
Been thanked: 1647 times
Post by Yambo »
If you've got to do a few square holes make a jig so they are all the same. :thumbup:
Has thanked: 1346 times
Been thanked: 1722 times
I've usually done like Yorick suggested and drilled holes at corners and cut it out with a jigsaw.
I now have a multitool but its fucking slow for that type of usage compared to a jigsaw.
That doesn't stop the fucking sparks from deafening every bugger on site by cutting every socket box out with a multitol though, feckless gimps.
Jeez, even a padsaw does the job.
demographic wrote: Tue Jan 23, 2024 9:03 pm I've usually done like Yorick suggested and drilled holes at corners and cut it out with a jigsaw.
Wooo :obscene-birdiedoublered:
That's from someone with O'level woodwork :banana-dance:
Has thanked: 2402 times
Been thanked: 3625 times
demographic wrote: Tue Jan 23, 2024 9:03 pm That doesn't stop the fucking sparks from deafening every bugger on site by cutting every socket box out with a multitool though
When you need one, they're the only tool for the job. But using a tool that sounds like a thousand angry wasps when there's a better way should be a stabbing offence.
Has thanked: 218 times
Been thanked: 689 times
mangocrazy wrote: Tue Jan 23, 2024 11:24 pm
IIRC it is.
But fun, nevertheless.
roadster
Has thanked: 15 times
Been thanked: 147 times
Post by roadster »
The high speed vibrating blade tools have saved me plenty of time and effort. But they are costly if you happen to hit a nail or some other hard obstruction because the blades are not very tough and are expensive.
formula400
Ok cool, a few different routs to go. I already have a jigsaw and drill.
I like the box cutter, but most of what I need to cut will be rectangular.
What will give me the cleanest finish??
CBR650r :mrgreen:
formula400
Rockburner wrote: Mon Jan 22, 2024 5:50 pm
[/quote]
As Yoz
[/quote]
CBR650r :mrgreen:
