Filenames & modified dates - listing as text
Has thanked: 6187 times
Been thanked: 5087 times
In Windows File Explorer
I have three sets of about 190 files
Is there an easy way of creating a text list, to go into a simple spreadsheet, listing each filename with its 'date modified'?
This is so i can eventually list all three sets as six parallel columns on the same spreadsheet.
Cheers :)
Been thanked: 7526 times
Re: Filenames & modified dates - listing as text
from the command prompt 'dir > list.txt'
EDIT:
You need to CD to the right directory first of course, but everyone knows how to use the CLI!
KungFooBob wrote: Thu Jun 23, 2022 4:23 pm from the command prompt 'dir > list.txt'
EDIT:
Errrr ... and command prompt is found where ... ?
Oh, hang on ....
On Win 10...
click start button/windows key
type "Command Prompt'
Select Command prompt from list :)
You'll have fun changing to the right directory :)
CMD does not support UNC paths
Been thanked: 2615 times
Files so old they have imperial threads?
Sorry for the pointless derail, but not sorry enough not to post it.
cheb wrote: Fri Jun 24, 2022 4:52 pm Files so old they have imperial threads?
No worries.
I've given up on it. Could output as a list, but only either filenames or as individual lines each filenames and time. Not going to manually edit that lot.
