Filenames & modified dates - listing as text
- Has thanked: 6200 times
- Been thanked: 5090 times
In Windows File Explorer
I have three sets of about 190 files
Is there an easy way of creating a text list, to go into a simple spreadsheet, listing each filename with its 'date modified'?
This is so i can eventually list all three sets as six parallel columns on the same spreadsheet.
Cheers
Cheers
- Been thanked: 7539 times
Re: Filenames & modified dates - listing as text
from the command prompt 'dir > list.txt'
EDIT:
You need to CD to the right directory first of course, but everyone knows how to use the CLI!
EDIT:
KungFooBob wrote: ↑Thu Jun 23, 2022 4:23 pm from the command prompt 'dir > list.txt'
EDIT:
Thanks
Errrr ... and command prompt is found where ... ?
Oh, hang on ....
On Win 10...
click start button/windows key
type "Command Prompt'
Select Command prompt from list
You'll have fun changing to the right directory
CMD does not support UNC paths
- Been thanked: 2619 times
Files so old they have imperial threads?
Sorry for the pointless derail, but not sorry enough not to post it.
No worries.
I've given up on it. Could output as a list, but only either filenames or as individual lines each filenames and time. Not going to manually edit that lot.
