Suspension Upgrade.
Has thanked: 12607 times
Been thanked: 8537 times
Suspension Upgrade.
The Husky is great, but I never managed to set up the suspension properly. Over here there's loads of different surfaces and terrains.
I've had it 3 years now and it's getting real bumpy and needs a refresh.
Just found there's a guy new to the island who's a suspension guru :)
He came Friday and set the sag which improved the rear loads.
Then he talked about full upgrade front and rear.
Just sent me the price.
Springs for my weight both ends. Posh oil.
Forks and shock fully rebuilt.
New bushes etc and more.
All Ktech stuff.
540€ the whole lot :) and he'll do it all in my garage.
I might learn summat :obscene-birdiedoublered:
Can't wait.
Has thanked: 20859 times
Been thanked: 13679 times
Re: Suspension Upgrade.
He's just turned up with your springs now! :lol:
tumblr 3
Taipan wrote: Tue May 10, 2022 1:04 pm He's just turned up with your springs now! :lol:
tumblr 3
Pass the pies :obscene-birdiedoublered:
That's cheap
Le_Fromage_Grande wrote: Tue May 10, 2022 1:29 pm That's cheap
Certainly not UK prices ;)
Has thanked: 2317 times
Been thanked: 1822 times
Post by Jody »
Can he pop over here when he's done and do the 690 for me !?
Been thanked: 15493 times
Jody wrote: Wed May 11, 2022 7:28 am Can he pop over here when he's done and do the 690 for me !?
Not really. Spring on the back isn't enough of a swap to help, it's a bit better, but not night and day. A shock is better.
Forks are fine and will be happy at the pointy end of an Inters trackday.
Hot_Air
Has thanked: 1454 times
Been thanked: 288 times
Post by Hot_Air »
Yorick wrote: Tue May 10, 2022 2:03 pm Certainly not UK prices ;)
You’re not kidding! I don’t dare think about the UK cost of a full (front and rear) suspension upgrade :o
gt alex
Has thanked: 7 times
Been thanked: 20 times
Post by gt alex »
That sounds too cheap to me but I'm the other side of the globe. Mine cost about 1/2 that and I already had the front springs and cartridge emulators.
All the rest I got as cheap as I could as long as it had the specs I wanted and I did all the work and setup myself.
Here that would just get the rear shock and spring. https://www.ktechsuspensionusa.com/p-20 ... shock.aspx
He's not getting a shock is he?
Shock service is £120-150. Set of front springs £60-90. Oils and bits £40-50
The rest is labour. So it's decent but not a give away.
Hi!!!!
Full maintenance front forks are 175€. SKF low friction oil and dust seal, 1.5L oil and 4 guide bushing. Complete full rebuild.
Rear shock, full rebuild 160€. Kit maintenance KTECH, KYB oil do it by vacum pump, nitrogen.
A part:
Front springs 110€
Rear schock spring 110€
All seems about what I'd expect
weeksy wrote: Sat May 14, 2022 9:12 am All seems about what I'd expect
I'm happy. And if I hadnt found him, I'd have to go to Las Palmas.
Hot_Air wrote: Thu May 12, 2022 11:46 pm
Budget £2k just to be safe.
Hot_Air
Post by Hot_Air »
Eek!
Whilst pratting about in the garage I was a bit surprised to see this..
Good job matey boy is coming next week :)
That was easier than expected. Youtube videos helped :)
But gonna get the dude to rebuild it. Don't trust myself and he'll be doing the sag and setup anyway.
You're allowed to get soapy bubbles on it at times you know.
lostboy
Has thanked: 2152 times
Been thanked: 426 times
Post by lostboy »
weeksy wrote: Tue May 24, 2022 12:59 pm You're allowed to get soapy bubbles on it at times you know.
You took over an hour longer to respond with that than I thought you would. Admirable restraint sir!
lostboy wrote: Tue May 24, 2022 1:03 pm
I was out on the KTM :)
