Moving phone app from internal memory to somewhere else
- Has thanked: 36 times
- Been thanked: 48 times
Hi guys. I have an app on my phone in internal storage that I want to move to either another phone or to the memory card. It's an app I can no longer find on the store and really want to keep it. I've tried moving it via settings but no luck. Any ideas. Tia
- Has thanked: 484 times
- Been thanked: 1427 times
Re: Moving phone app from internal memory to somewhere else
Any chance its in use in the background. Force stop then try and move
- MrLongbeard
- Has thanked: 599 times
- Been thanked: 2443 times
If android just have a search for the APK file on the web, assuming it's not been removed from the store because it's dodgy
Not dodgy as far as I know, it works fine and antivirus hasn't picked anything upMrLongbeard wrote: ↑Sat Dec 04, 2021 6:17 pm If android just have a search for the APK file on the web, assuming it's not been removed from the store because it's dodgy
- Been thanked: 7530 times
iirc, if you do find the apk, you might need to put the handset in developer mode to install it, or there might be an option in settings to 'allow untrusted apps'. Developer mode is really simple to turn on if you need too, even for a secret option
- MrLongbeard
Google search 'name of app' APK, if you find it you need to be sure it's from a safe site and hasn't been dicked with, or risk it.
- Cousin Jack
- Has thanked: 2551 times
- Been thanked: 2286 times
At least some Androids have a nasty habit of NOT letting you move some apps onto an SD card. My Samsung has some that came with the phone, have never been used, won't uninstall and refuse to move to the SD card!
