What's best.???
As a kid until now, just used 3 in 1 or similar general maintenance oil. But now with two new bikes in the family, starting to wonder if I should be using something a bit more specific. General road/lane use, so bikes don't get too dirty.
Bicycle chain lube
- Has thanked: 1745 times
- Been thanked: 2085 times
- Has thanked: 5450 times
- Been thanked: 13085 times
Re: Bicycle chain lube
Me, i just go with GT-85 which gets plenty of frowns from many cyclists... but not all.
Funnily though i use the same on motorbikes too... which gets the same levels of frown.
Putoline wax is supposedly the king of lube if doing it like some say...
I can't see any reason a decent motorbike lube wouldn't work well though, i have Wurth Dry lube i use at times, can't see why it wouldn't do a decent job on a bicycle.
- Has thanked: 1829 times
- Been thanked: 1469 times
TBH, they are much of a muchness ...
Make sure the chain is lube - and also make sure you clean it regularly
I wouldn't just use GT-85 - but that approach hasn't killed Weeksy yet, so we can assume it works.
I use weldtite TF2 wax, doesn't clog up the cassette like oil based lubes
https://www.ebay.co.uk/itm/362949133772
