CANDY CRUSH: THE LAST CB750 ORIGIN8OR WILL EVER BUILD
Been thanked: 2727 times
Re: CANDY CRUSH: THE LAST CB750 ORIGIN8OR WILL EVER BUILD
That's good.
It's okay, better than most cafe racers
Has thanked: 778 times
Been thanked: 3216 times
Burn it with fire
bevvo
Has thanked: 83 times
Been thanked: 129 times
Post by bevvo »
Obviously, this has better brakes and suspension, and some lovely paintwork. But for me, it still adds up to less than a simple restoration of the original.
lostboy
Has thanked: 2152 times
Been thanked: 426 times
Post by lostboy »
The more of these that you post up the easier I'm finding it to open the thread and just go "yes" or "no". There's clearly things about the bikes that are either doing it for me or not but I'm not sure what they are - I'm finding that I don't even need to look at the detail to decide.
This one is a very firm no.
You'd think they could have found a clutch lever to match the front brake lever.
Been thanked: 13671 times
Hate the bodywork.
Bigjawa
Has thanked: 225 times
Been thanked: 969 times
Post by Bigjawa »
Like that, doesn't have the empty gap in the middle.
Has thanked: 10959 times
Been thanked: 3995 times
KungFooBob wrote: Fri May 21, 2021 9:08 am You'd think they could have found a clutch lever to match the front brake lever.
It's little things like that , and the welding on the oil-tank* that let some of these specials down and make them look like they've been bodged together in a hurry.
* no - I couldn't do better, but lots of other people could....
Has thanked: 2556 times
Been thanked: 4167 times
Oil tank looks like a hastily-added afterthought when they realised that the CB750 is a dry-sump motor. And why didn't they paint it to match the seat/tank?
G.P
Has thanked: 1994 times
Been thanked: 1283 times
Post by G.P »
Hmm, Paint the oil tank, put a trad headlight on it and lose the poncy seat cover for something more simple and It'd be OK
Has thanked: 12605 times
Has thanked: 2908 times
Been thanked: 1678 times
weeksy wrote: Fri May 21, 2021 6:13 am the-last-cb750-origin8or-will-ever-build
Can't say I'm too sorry about that... leave 'em original and get back to making them look like the manufacturer intended rather than sticking tat all over them and calling it a 'custom'.
Has thanked: 1059 times
Been thanked: 1646 times
I quite like that.
Not keen on pod filters, as usual.
I assume the carbs are made by Bing? The only carb I've ever seen with a spring clip that holds the float bowl in place was on a 94 (or so) Maico 250.
On a single cylinder motocrosser the quick release removable float bowl is a good idea, on an inline four I think drain screws are maybe a better idea cos I reckon you'd struggle to get the float bowl off without taking the carb off anyway.
Could easy be good carbs though, I dunno.
Druid
Has thanked: 351 times
Been thanked: 1106 times
Post by Druid »
Carbs are Keihins, they look like OE carbs which had a spring clip instead of screws to retain the float bowls.
That's so you don't get them mixed up. :thumbup:
This one conjures quite massive indifference in me. I was never fond of the wheezy CB750 engine anyway.
Druid wrote: Fri May 21, 2021 7:23 pm Carbs are Keihins, they look like OE carbs which had a spring clip instead of screws to retain the float bowls.
Ahh, right.
I've not noticed any with the clips apart from on the Bing I had.
