CANDY CRUSH: THE LAST CB750 ORIGIN8OR WILL EVER BUILD
- Has thanked: 5504 times
- Been thanked: 12764 times
- Been thanked: 2501 times
- Has thanked: 626 times
- Been thanked: 4072 times
Re: CANDY CRUSH: THE LAST CB750 ORIGIN8OR WILL EVER BUILD
It's okay, better than most cafe racers
- Has thanked: 579 times
- Been thanked: 2289 times
Obviously, this has better brakes and suspension, and some lovely paintwork. But for me, it still adds up to less than a simple restoration of the original.
- Has thanked: 2192 times
- Been thanked: 426 times
The more of these that you post up the easier I'm finding it to open the thread and just go "yes" or "no". There's clearly things about the bikes that are either doing it for me or not but I'm not sure what they are - I'm finding that I don't even need to look at the detail to decide.
This one is a very firm no.
- Has thanked: 532 times
- Been thanked: 7241 times
You'd think they could have found a clutch lever to match the front brake lever.
- Has thanked: 15613 times
- Been thanked: 9853 times
- Has thanked: 7727 times
- Been thanked: 2401 times
It's little things like that , and the welding on the oil-tank* that let some of these specials down and make them look like they've been bodged together in a hurry.KungFooBob wrote: ↑Fri May 21, 2021 9:08 am You'd think they could have found a clutch lever to match the front brake lever.
* no - I couldn't do better, but lots of other people could....
- Has thanked: 2324 times
- Been thanked: 3375 times
Oil tank looks like a hastily-added afterthought when they realised that the CB750 is a dry-sump motor. And why didn't they paint it to match the seat/tank?
- G.P
- Has thanked: 2113 times
- Been thanked: 1310 times
Hmm, Paint the oil tank, put a trad headlight on it and lose the poncy seat cover for something more simple and It'd be OK
- Has thanked: 10117 times
- Been thanked: 6649 times
- Has thanked: 2632 times
- Been thanked: 1498 times
Can't say I'm too sorry about that... leave 'em original and get back to making them look like the manufacturer intended rather than sticking tat all over them and calling it a 'custom'.
- Has thanked: 1326 times
- Been thanked: 1652 times
I quite like that.
Not keen on pod filters, as usual.
I assume the carbs are made by Bing? The only carb I've ever seen with a spring clip that holds the float bowl in place was on a 94 (or so) Maico 250.
On a single cylinder motocrosser the quick release removable float bowl is a good idea, on an inline four I think drain screws are maybe a better idea cos I reckon you'd struggle to get the float bowl off without taking the carb off anyway.
Could easy be good carbs though, I dunno.
- Has thanked: 9690 times
- Been thanked: 9704 times
That's so you don't get them mixed up.KungFooBob wrote: ↑Fri May 21, 2021 9:08 am You'd think they could have found a clutch lever to match the front brake lever.
This one conjures quite massive indifference in me. I was never fond of the wheezy CB750 engine anyway.
Ahh, right.
I've not noticed any with the clips apart from on the Bing I had.
