Winter projects, purchases, upgrades ?
What you got for winter then ?
I must admit, i've got nothing this year. I'd LIKE a down blipper on the XSR, but the expense is just too great for the actual benefit.
The ZX6R has had it's oil change done already and is good to go, but i think Mrs Weeksy is planning a couple/three trackdays before Portimao so will need to factor in some extra tyres i hadn't planned.
But there's no incoming bikes or bits this year.... I'm hoping you all have some though.
Re: Winter projects, purchases, upgrades ?
New tyres is all the CBR needs.
Bonnie currently has no cylinders or head, they're off being fixed. When they come back I'll put it all back together, fit new throttle cables, new clutch cable, try and stop the speedo rattling, fix the HT leads, sort the fuel levels in the carbs.
Then when all thats done contemplate changing its tyres myself. Still in two minds on that one.
Plenty to keep me going :D
Mr. Dazzle wrote: Tue Nov 03, 2020 8:25 am New tyres is all the CBR needs.
Man that needs some thread time...
Thread is already there, I just have nothing to put in it ATM. Waiting for the head and cylinders :D
Has thanked: 1926 times
Been thanked: 1728 times
The T309 - new fork internals and re chrome ....
New shock in the post - wheel corrosion be tackled at the moment. Then may pay a detail to try and clean up some of the scratches in the paintwork ...
Other than that - nothing else on bikes ...
A rather tatty YPVS 350 that I'm gradually rebuilding to how I want, a Z1000J with an 1170 engine and a load of other modifications that needs it carbs stripping and cleaning (again) and an FZ750 that is fine to ride, but I have got a 911cc race engine for it sat in the garage doing nothing. I've also got an FZR400 that needs it's chain adjusting, and if I get bored I might put a TZ250 seat unit on it.
G.P
Has thanked: 1994 times
Been thanked: 1283 times
Post by G.P »
Same old story here.
2 x 900SS Ducatis; one isn't far off being able to fire up. the other still has the engine on the bench.
Focus will be on the trackbike. bar some potential metal fab as the rear of the subframe for a seat, it only needs exhausts, oil cooler and fuel pump & filter sorting (they live inside the tank which needs painting..).
Need to give the Triumph Tiger a good clean and ACF50. Its probably going to live outside over winter to leave some more room so I'll give it some love first!
I need to put an MOT on the Yamaha Trailways, it might get sold as No.2 son wants a twist and go scoot to start with.
The Monster 1200 doesn't need anything apart from being ridden :)
G.P wrote: Tue Nov 03, 2020 9:17 am Same old story here.
What scheme you planning on both now?
Bigyin
Has thanked: 1436 times
Been thanked: 2738 times
Post by Bigyin »
The Fazer needs a service which wont take much but the Ducati is ready for next year once its MOT'ed tomorrow.
No chance of buying any more bikes over the winter for me though.....nowhere to put any more unless i build a gaarge first :thumbdown:
There's a couple of things I'd *like done to the Zed over the Winter.
Fit a set of heated grips. I always use Summer gloves and some coldish days my old pinkies suffer.
Either a revalve,or a cartridge mod on the forks. The rear Ohlins is good enough,but the forks feel a bit cheap seats.
*time and life permitting
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
Already fitted a Vape ignition to my MZ , also converted to 12volts.
Just picked up a Mikuni VM30 carb , brand new , so will be purchasing jets and
making a few tweaks to fit it to my MZ.
kendo57 wrote: Thu Nov 05, 2020 8:04 pm Already ready fitted a Vape ignition to my MZ , also converted to 12volts.
What MZ?
kendo57
Post by kendo57 »
MZ 250 G5 ISDT
Cool stuff... i know absolutely nothing about it... but yeah, nice one.
Do you use it for Long Distance Trials of anything like that?
Newey
Has thanked: 58 times
Been thanked: 66 times
Post by Newey »
GPR steering damper for the XSR, clean it, change the oil then to bed with it. I'm considering an ABBA sky stand just because the wife wants to get me something for that December holiday time. I'll look over the Husqvarna ready to sell it to make room for a FJR or similar.
Harry wrote: Fri Nov 06, 2020 2:43 am My winter project is fixing up an old yacht from the late 70's. It's a beautiful thing made when all the interiors were teak and solidly built, instead of modern Ikea type interiors made of plastic and composite.
LEts see then :)
Nidge
Has thanked: 684 times
Been thanked: 673 times
Post by Nidge »
So I've picked up another T140 this is an E model denoting emissions compliance for the American market required by the late 70s, so it has electronic ignition, Mk2 Amal carbs and parallel (as opposed to splayed) inlet ports. It's a 1981 model and need a few bits doing top it- firstly the carbs need a rebuild to get it running smoothly (this is typically the choke plungers needing replacing) , but the engine itself is the quietest T140 I've ever heard. Other things I will do will be to replace the UK style tank with a spare US one I have and some general tidying up, but with stainless rims and rear mudguard there is very little corrosion to address.
When I were a lad, I had a toy motorbike that looked exactly like that
Thats proper teak decking....literally. :D Looks like it could come off the back of a Rolls-Royce.
Much as I love Carbon Fibre (I made a living from it for >10 years) you can't beat a nice bit of wood* IMO.
*Well you can, but that's different
