Recommend me some bars
- Has thanked: 1926 times
- Been thanked: 1728 times
Having bought some carbon bars - and found out he are 31.5mm, i would like to buy some 35mm bars with a 35mm /40 mm rise. 780 mm width
For an e-bike - so alloy.
Any recommendations?
- Been thanked: 15488 times
Re: Recommend me some bars
Generally Burgtec or DMR really. I guess Renthal as well or one up as well.
Depends on things like backsweep as well.
I run the standard Bontrager which are 28mm rise
- Been thanked: 9495 times
mboy
- Has thanked: 854 times
- Been thanked: 696 times
Not used em myself, but everyone is raving about OneUp bars right now... Personally I stay away from 35mm bar clamp stuff, it's unnecessarily stiff (and way larger than the clamp on a motorbike for instance!), but if you don't have any choice for whatever reason, I'm reliably informed that the OneUp bars are the most comfortable 35mm clamp bars because of the unique way that they are profiled at the bends... Alloy or Carbon...
TBH, I am not a fan of 35mm but it is what is on the Trek Rail. The other option is a) to change the knockbock stem b) fit a shim ....mboy wrote: Wed Mar 04, 2026 11:36 pm Not used em myself, but everyone is raving about OneUp bars right now... Personally I stay away from 35mm bar clamp stuff, it's unnecessarily stiff (and way larger than the clamp on a motorbike for instance!), but if you don't have any choice for whatever reason, I'm reliably informed that the OneUp bars are the most comfortable 35mm clamp bars because of the unique way that they are profiled at the bends... Alloy or Carbon...
- Has thanked: 3644 times
- Been thanked: 2502 times
https://www.stantonbikes.com/products/stanton-ti-bar
I've got a pair of these on the Curtis, it did have a Ti flat bar before (RUST components I think). I like them, though still not convinced they're any better than the RUST bars but I can't be bothered with the faff of swapping back.
No such thing as 31.5
Edit . Lol sorry, brain ain't working
https://www.jejamescycles.com/product/3 ... 2FzVYH0pbA
31.8 which is standard narrower dia bars
