How would you go about removing the screws of the IaCV from this throttle body
katana
Has thanked: 77 times
Been thanked: 54 times
Post by katana »
Evening all,
Am having a bit of fun with the ex trog toyota corolla. It is a VVTI 1.4 UK built corolla GS. The tick over sits high so looking to replace the IACV (Idle Air Control Valve) Now the fun starts, I can't get the screws to come out. Have tried vessel JIS screwdrivers and a philips screwdriver and all I have managed to do is slightly turn two of the four screws. So what would you do to get the screws out as they have been there for 25 years so need a bit of persuation to remove.
So what would you do next to try and get the screws out. I'm thinking impact driver, or should I use some cold or heat before hand. Leave in the frezzer for a few days. Maybe better to drill a hole in the center of the fucked screws and hammer in a torx bit and then the impact driver. Or what would you recomend.
This is a picture of the throttle body
This is the parts diagram and the IACV is 22270
https://www.autozone.com/fuel-delivery/ ... 331333_0_0 follow the link and picture three is of the screws in question
Eclipse
Has thanked: 263 times
Been thanked: 274 times
Re: How would you go about removing the screws of the IaCV from this throttle body
Post by Eclipse »
Impact might bend the shaft, I would try localised heat and get the screw nice and hot,
The screw and area will expand/retract and hopefully break the bond.
Gas soldering iron with torch tip would be ideal for this.
iansoady
Has thanked: 72 times
Been thanked: 244 times
Post by iansoady »
I'm guessing the offending item is the black comonent to the bottom right of the body. It looks like plastic so I'd be very careful with heat. However, if you're replacing anyway it might be worth sonstructively dismantling with a cutting disc in a dremel. The damger with excessive heat / impact is distorting the injector body itself.
Eclipse
Post by Eclipse »
I thought he was talking about the butterfly valve lol
Yeah if its plastic don't put heat anywhere near it.
I think he means these screws. The two arrowed and two on the other side you can't see.
iansoady
Post by iansoady »
I thought it was the ones going vertically upwards through the plastic bit.
iansoady wrote: Thu Jul 10, 2025 4:08 pm I thought it was the ones going vertically upwards through the plastic bit.
But that looks like it's only held on with two screws rather than four.
katana
Post by katana »
Eclipse wrote: Thu Jul 10, 2025 1:47 am Impact might bend the shaft, I would try localised heat and get the screw nice and hot,
As kung foo bob pointed out the screws, I'm not sure that I can use an impact driver as not sure if I can place the throttle body on a surface where I can hammer the impact driver with out possibly damaging something else. Though, I have a chefs blow torch so localised heat should be easy enough
iansoady wrote: Thu Jul 10, 2025 10:04 am I'm guessing the offending item is the black comonent to the bottom right of the body. It looks like plastic so I'd be very careful with heat. However, if you're replacing anyway it might be worth sonstructively dismantling with a cutting disc in a dremel. The damger with excessive heat / impact is distorting the injector body itself.
Actually the cutting off might be an idea. Am thinking angle grinder and thin disc.
Eclipse wrote: Thu Jul 10, 2025 1:53 pm I thought he was talking about the butterfly valve lol
Throttle position sensor, which I think isn't physically adjustable.
KungFooBob wrote: Thu Jul 10, 2025 2:03 pm I think he means these screws. The two arrowed and two on the other side you can't see.
Looking at the photos the screws go all the way through, so was thinking very small drill bit and dripping a bit of oil to cool the drill and then mole grips the screws out.
Has thanked: 2288 times
Been thanked: 2673 times
Stretch a rubber band over the screwdriver tip
A_morti
Has thanked: 412 times
Been thanked: 824 times
Post by A_morti »
Pretty strong odds it's been slathered in loctite. If you're lucky, as that will also block corrosion in the threads. Heat will melt that.
katana
Post by katana »
ZRX61 wrote: Tue Jul 15, 2025 7:19 pm Stretch a rubber band over the screwdriver tip
Won't work, I think, as i tried the two screw heads with JIS and philips that is can be. The bits cammed out.
