Need Small Clamps
Has thanked: 12620 times
Been thanked: 8541 times
Need Small Clamps
The main joint into the pool pump split recently and I bodged it with big G-clamp.
I need a prettier and smaller solution. Maybe a small clamp on a nut and screw jobby. I know what I think, just can't explain.
The big clamp is gonna get knocked off, so want 2 or 3 smaller jobbies instead.
Any ideas?
Been thanked: 9504 times
Re: Need Small Clamps
Or you could replace the broken part?
KungFooBob wrote: Sat Feb 08, 2025 3:11 pm Or you could replace the broken part?
All the joints have been glued. My plumber pal says he'll need to rip everything out and start again.
He's busy and want a better solution than I have now.
Has thanked: 3016 times
Been thanked: 2528 times
If that is working I might be inclined to try 3 small G clamps spaced around the rim.
Amazon do several sizes
A_morti
Has thanked: 412 times
Been thanked: 824 times
Post by A_morti »
Broken up the link so I can post it:
https://www.amazon.
es/-/en/dp/B0CWH6Z7D9
Been thanked: 14171 times
What about a pipe clamp?
Leave the G clamp in position until the pipe clamp is tightened,then remove the G clamp.
https://www.fischer.co.uk/en-gb/product ... ipe-clamps
Has thanked: 717 times
Been thanked: 2045 times
Measure the fucked part and buy some flange clamps or just go but the correct broken part.
Felix wrote: Wed Feb 12, 2025 12:44 am Measure the fucked part and buy some flange clamps or just go but the correct broken part.
He sed flange.
fnaar.
Been thanked: 4529 times
What about nipple clamps?
Been thanked: 5884 times
Can't help, but you should think about treating yourself to a nice pedicure. ;)
