Hanging a paddock stand in a shed
- formula400
- Has thanked: 482 times
- Been thanked: 1045 times
- Contact:
Right, I’ve got an Oxford premium paddock stand.
It’s big and ugly, I’d like to either hang it in the wall or even better, in the inside of roof on the slant.
Any genius ideas how to achieve this???
Or another option, get a water proof cover and hang it in the rear of the shed that no one can see
CBR650r
- Been thanked: 14171 times
Re: Hanging a paddock stand in a shed
If you don't use it,sell it. If you are keeping it,make very sure it's well secured if up above things. If anything can fall,it will and it'll land on expensive things like paintwork and totally spoil your day.
- Has thanked: 1059 times
- Been thanked: 1646 times
Standard operating procedure is to hang it near the door at a height where you bang your head on it every bastard time you walk in on a night.
Ideally if you want the extra points you use a fairly crappy hook so it then falls off and dings expensive stuff underneath it.
If you can lay a rake on the floor tines facing up as well thats all bases covered.
- Has thanked: 10971 times
- Been thanked: 4004 times
Funnily enough I actually did the rake trick last weekend..... (I have a rake lurking round the back of the shed for tidying the gravel occasionally, and yes I stepped on the pointy end and got whacked in the face.)demographic wrote: Sat Jan 25, 2025 5:12 pm Standard operating procedure is to hang it near the door at a height where you bang your head on it every bastard time you walk in on a night.
The OP loses points for not having one of the collapsible paddock stands.
I think I'm the only person who ever bought one.
- Has thanked: 2558 times
- Been thanked: 4168 times
Every so often Aldi/Lidl do a hook set which contains the kind of metallic items that might be suitable. The next time I'm in the shed with a camera I'll try to remember to take a photo of my (wall mounted) paddock stand collection.
I have a particularly bad memory these days...
- ChrisW
- Has thanked: 3714 times
- Been thanked: 3027 times
If you are going to do it still go for the ceiling - I'd use three of the plastic/rubber coated self-tapping hooks that you get in the likes of B&Q etc. and twist one or more of them into place once the stand was up there so that it couldn't fall.
It still might, though... I used to keep BMX frames hung from the ceiling and one of them once sent me to A&E to have my scalp glued up.
- Druid
- Has thanked: 352 times
- Been thanked: 1109 times
I use one of these to hang a single sided rear paddock stand from the roof of my garage. Been there for many years and not fallen down yetChrisW wrote: Sat Jan 25, 2025 7:23 pm If you are going to do it still go for the ceiling - I'd use three of the plastic/rubber coated self-tapping hooks that you get in the likes of B&Q etc. and twist one or more of them into place once the stand was up there so that it couldn't fall.
- Has thanked: 2862 times
- Been thanked: 3518 times
I just push mine under the side of a bike, pretty much out of the way and no worries about it falling.
- formula400
- Contact:
Dodgy69 wrote: Sun Jan 26, 2025 9:24 am I just push mine under the side of a bike, pretty much out of the way and no worries about it falling.![]()
I’ve only got a little shed. I get sick of moving stuff out of the way.
Not much love for hanging it up.
I think the best idea is maybe just leave it, burn it or hang it at the back outside, sod it falling on me or the boy.
CBR650r
- Been thanked: 9505 times
I've got three sets of rails up in the garage that you can slot various hooks and things on to and move them around. One even has a hook for holding a bicycle. I hook my panniers and paddock stands on them, there's even a basket. You can just make out two of them in this pic.
I can't remember the brand and it looks like B&Q don't list them anymore. They're like these ones from Argos, but nicer.
https://www.argos.co.uk/product/3115789
EDIT:
You can see them better in this pic...
EDIT:
- Has thanked: 2296 times
- Been thanked: 2684 times
Mine are under bikes, except when I'm out on a bike... in which case it sits on the floor awaiting my return.
