Cordless Power Wrench/Rachet
Been thanked: 9505 times
I keep watching those short little videos the Friendface algorithm feeds you.
All the vehicle maintenance ones seem to involve someone using a battery powered ratchet.
So far they've all been red, so assume they're Milwaukee ones, something like this...
So now I want one.
Anyone got one, do they have the torque needed for most jobs, or would you be better off with proper impact driver (unless clearance is an issue)?
Has thanked: 2558 times
Been thanked: 4168 times
Re: Cordless Power Wrench/Rachet
Compressed air ratchets are also available in red, but probably don't qualify as cordless...
Has thanked: 717 times
Been thanked: 2045 times
A friend has one. Cant remember exact but it is under 100Nm but came in handy doing the top bearing in my van and getting in to take the wing off to allow me to change the door. The battery is different from the drill ones but at least the charger does both types.
75Nm
https://www.powertoolmate.co.uk/power-t ... =894&gQT=1
Has thanked: 12620 times
Been thanked: 8541 times
When I was at Portimao, they used a Makita 18v jobby to take the sprocket nut off. No need to hold the rear brake.
Just whizzed it off.
dern
Has thanked: 1187 times
Been thanked: 2281 times
Post by dern »
I have both the Milwaukee impact gun and wrench. Unfortunately I haven’t used the wrench yet so can’t really help. It does seem pretty powerful but I’d get the impact gun first and then the wrench unless you know you won’t have space to use the gun.
The quality of the Milwaukee stuff is superb by the way.
dern wrote: Thu Jan 02, 2025 10:21 pm The quality of the Milwaukee stuff is superb by the way.
TBF Makita are a close 2nd, well apart from the drills. My rattle gun, impact driver, angle grinder and circular raw are excellent but sadly i killed two drills. I was told the gearing was made from plastics and my two fucked up when using the hammer so probably correct. I went to Milwaukee for my drill and happy as a pig in shit so far but never used it for much hammer work drilling in the six month i have owned it so time will tell.
Has thanked: 2296 times
Been thanked: 2684 times
Milwaukee were quite respected until the cordless rattle gun debacle where they replaced the amazingly good one, with one that is made from cheese.
Sadlonelygit
Has thanked: 94 times
Been thanked: 796 times
Post by Sadlonelygit »
Treated myself to a £26 no name Makita copy before Xmas. Managed to undo the top nut on a MacPherson strut, which is what it was bought for. They claimed 540nm, but it won't touch the merc's wheel nuts (210ft/lb).
Would hope that a brand name tool would have been tested to claimed figures!
Nordboy
Has thanked: 580 times
Been thanked: 830 times
Post by Nordboy »
They do look handy, especially for getting into tighter spaces. I just looked at the De walt ones as that's the batteries I have. All of their versions only quote around 100Nm torque.
Still probably more than I could manage for some jobs though. Not cheap though £150+
Nordboy wrote: Fri Jan 03, 2025 12:51 pm They do look handy, especially for getting into tighter spaces. I just looked at the De walt ones as that's the batteries I have. All of their versions only quote around 100Nm torque.
DCF900B is 1898N/m (claimed)
Nordboy
Post by Nordboy »
ZRX61 wrote: Fri Jan 03, 2025 3:25 pm
That's an impact drill though, compared to the impact rachets.
Nordboy wrote: Fri Jan 03, 2025 5:20 pm That's an impact drill though, compared to the impact rachets.
Not actually a drill.
I was under the impression that heavy duty dugga-duggas were referred to as impact guns. Impact-assisted screwdrivers are impact drivers. Impact ratchets occupy some sort of middle ground (or so it seems to me).
dern
Post by dern »
Cordless impact wrenches and ratchets both have socket drivers in various sizes like half or three quarter inch. An impact wrench (dugga) will loosen and tighten using impact forces and then torque. A ratchet (first picture of thread) will loosen and tighten by torque alone. There may be some impact mechanism but it won’t be as strong as an impact wrench.
An impact driver has a quarter inch hex chuck for took bits and is primarily used for screws but you can get various sized bits, including small sockets for coach screws.
A drill just has a Jacob’s chuck but may have an impact mechanism for masonry drills.
There is a slight overlap with all of these things but they intended for different jobs and I wouldn’t buy one of them hoping that it would do the job of more than one.
Druid
Has thanked: 352 times
Been thanked: 1109 times
Post by Druid »
dern wrote: Sat Jan 04, 2025 11:37 am
This is proper bloke's reasoning. It's the reason why my garage is so full of tools ands tool storage that I need to build an extension
Druid wrote: Sat Jan 04, 2025 7:51 pm This is proper bloke's reasoning. It's the reason why my garage is so full of tools ands tool storage that I need to build an extension
I haven't bought any tools* all year :)
* I did pick up some old 40's-70's USN tech manuals though.
Has thanked: 7636 times
Been thanked: 5937 times
ZRX61 wrote: Sun Jan 05, 2025 2:34 am
Although it is only Jan 5th ;)
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
Air ratchets were used all the time when i was a mechanic, great for getting to bell housing bolts, starter bolts ect.
You could usually crack the bolt off manually with the ratchet then use the air function to drive the bolt out.
My air ratchet is a lot slimmer than those battery ones though.
kendo57 wrote: Sun Jan 05, 2025 11:47 am My air ratchet is a lot slimmer than those battery ones though.
Not when you factor in the compressor :)
