You know when you have a 'good' idea
Sadlonelygit
Has thanked: 94 times
Been thanked: 796 times
Post by Sadlonelygit »
Splashed out pennies a while back on a no name 19mm rcs, all singing, all dancing multi adjustable master cylinder.
Only thing being.....nowhere to mount a switch!
So I duly order a hydraulic unit, which in the due course of time has now failed.
So of course, my MOT is due on the 1st of Jan, so must be replaced expeditiously.
Cue calipers off and pistons pumped out as far as possible, 1m length of tubing off the bleed nipple pumped full of dot 4.
Drop the offending banjo bolt, insert new one asap.
Press pistons back into the caliper, attach mityvac to m/c nipple, crack caliper nipple with the tubing on, steady with the vacuum big boy, watch the hose!
Leave ¼" in the long hose, nip all nipples up, job jobbed.
Do wonder if not messing about in the first place and just having to undo 2 screws may have been easier!
Has thanked: 12607 times
Been thanked: 8537 times
Re: You know when you have a 'good' idea
RCS?
Sadlonelygit
Ratio click system
Sadlonelygit wrote: Fri Nov 29, 2024 3:17 pm Ratio click system
Wassat?
Sorry to appear stupid.
Sadlonelygit
Sadlonelygit
Screwdriver wrote: Fri Nov 29, 2024 4:26 pm
Sadlonelygit wrote: Fri Nov 29, 2024 3:02 pm Splashed out pennies a while back on a no name 19mm rcs, all singing, all dancing multi adjustable master cylinder.
Well if it's anything like me, I think the problem is you have a great idea and try it out. Then, rather than determine whether or not that really was a good idea, it becomes more of a quest to force the bastard thing to work.
I'm with Elon Musk on this: "the best part is no part".
Originally I was changing all the lines to braided, so the initial fitting was 'less' troublesome. Hopefully this will be a 4-5 yearly occurrence.......which hopefully means it will be someone else's problem next time.
Has thanked: 20859 times
Been thanked: 13679 times
Yorick wrote: Fri Nov 29, 2024 3:26 pm
Wassat?
S’okay we’re used to it! :roll:
:mrgreen: :obscene-birdiedoublered:
Been thanked: 1228 times
Screwdriver wrote: Fri Nov 29, 2024 4:26 pm I'm with Elon Musk on this: "the best part is no part".
The handbook for my 1954 197cc Francis-Barnett Falcon stated that “the purpose of art is to conceal art.”
Also had instructions for cleaning the piston ring grooves.
A modern vehicle handbook tells you not to drink the contents of the battery.
Has thanked: 1059 times
Been thanked: 1646 times
Must admit that I've had a couple of those hydraulic brake banjo bolt switches fail.
Possibly cos they were just one crap manufacturer and I was just too cheap to get a better one but I prefer a pretty normal clicky microswitch type given the choice.
Plus, they were really damn long and stuck out a bleedin mile.
A_morti
Has thanked: 412 times
Been thanked: 824 times
Post by A_morti »
You still find mechanical micro switches in cars. If hydraulic switches were cheaper to install and/or more reliable, they'd be in there.
