- Has thanked: 602 times
- Been thanked: 4527 times
I think my KH500 cost £500 in 1986 in reasonable condition, I was a disappointed with it as it wasn't as fast as a 350LC, so I traded it back for my LC, I lost £30 on that deal
- derek badger
- Has thanked: 1089 times
- Been thanked: 1741 times
I've just got a stiffy...there's nothing about this I don't like.
- Has thanked: 6116 times
- Been thanked: 15468 times
Oh there's LOADS i don't like about that.... baiscally 99% of it.
- Has thanked: 245 times
- Been thanked: 1227 times
- Contact:
The go-faster holes in the brakes are a bit “Ogri’s friend Malcolm.”
Not the worst power valve I've ever seen, but certainly not the nicest either, it'd look better with a TZ seat and painted white with red stripederek badger wrote: Fri Jan 22, 2021 11:49 am I've just got a stiffy...there's nothing about this I don't like.
- rodbargee
- Has thanked: 397 times
- Been thanked: 1114 times
- Contact:
I had a H2 b I think it was and spent a fortune on it and eventually let it go, the pipes are 3k ish for a good set (when and if you can find any) Petrol cap (common to the Z1 over £100) much better off buying one thats been done.Scuffmark wrote: Fri Jan 22, 2021 10:27 amSkub wrote: Thu Jan 21, 2021 2:57 pm How about a lockdown restoration project? Would you hand over £3550 for this one?
https://www.ebay.co.uk/itm/1974-Kawasak ... 0009.m1982
Can't think why but I like that![]()
Maybe it reminds me of the bikes I grew up looking at as a pre-teenager?.... Don't think I'd want to pay £3.5k for it though.
- ogri
- Has thanked: 1269 times
- Been thanked: 337 times
Ahem, probably more to do with cooling them to help prevent fading?
Would like to hear them pipes
Really?weeksy wrote: Fri Jan 22, 2021 12:28 pm Oh there's LOADS i don't like about that.... baiscally 99% of it.
- Contact:
I wonder if you could tuck your right knee into that cutout, without setting your boot on fire on the exhaust.inewham wrote: Fri Jan 22, 2021 2:29 pm I don't like the tank, looks like someone's done a (very neat) cut and shut job on an old steel tank. Chopped off the rear quarters then welded them back on the other side (inside out).
- Contact:
I think it’ll help prevent brake fade about as much as farting helps to drown out thunder.
- rodbargee
- Contact:
- Been thanked: 9465 times
Doesn't the fairing and clipons just make it a 900ss?
I like it though
I like it though
Nah, the SS and the Monster have totally different frames/swingarms.
I think the Monster frame is more similar to the 851/888 frames.
- Druid
- Has thanked: 351 times
- Been thanked: 1106 times
The frames are both made from bits of straight tube welded welded into triangular shapes. I think most people couldn't tell the difference - including me, and I own a MonsterKungFooBob wrote: Sat Jan 23, 2021 7:04 pm Nah, the SS and the Monster have totally different frames/swingarms.
The rear suspension is very very different between the Monster and the SS. The SS is a driect link between the frame and swingarm, the Monster has a kind of rising rate linkage with a ride height adjuster.
The frames are very different if you look carefully. It's much much easier to change the belts on an SS.
Where's GP when you need him?
Older SS frame...
Monster 900...
Older SS frame...
Monster 900...
- Has thanked: 12565 times
- Been thanked: 8521 times
Early Monster frames are closer to 851 frames than 900AS frames, I think the Monster frame is the same as the ST2, dunno why they bothered though, still got a dumper truck engine coupled to a tractor gearbox.
First thing that came to mind was a trx 850 Yamaha when I saw this.
Pgm wrote: Sun Jan 24, 2021 5:41 amFirst thing that came to mind was a trx 850 Yamaha when I saw this.
