Been thanked: 4527 times
I think my KH500 cost £500 in 1986 in reasonable condition, I was a disappointed with it as it wasn't as fast as a 350LC, so I traded it back for my LC, I lost £30 on that deal
derek badger
Has thanked: 1089 times
Been thanked: 1741 times
Post by derek badger »
I've just got a stiffy...there's nothing about this I don't like.
Has thanked: 6116 times
Been thanked: 15468 times
Oh there's LOADS i don't like about that.... baiscally 99% of it.
Been thanked: 1227 times
rodbargee wrote: Thu Jan 21, 2021 7:27 pm Image
The go-faster holes in the brakes are a bit “Ogri’s friend Malcolm.”
derek badger wrote: Fri Jan 22, 2021 11:49 am I've just got a stiffy...there's nothing about this I don't like.
Not the worst power valve I've ever seen, but certainly not the nicest either, it'd look better with a TZ seat and painted white with red stripe
rodbargee
Has thanked: 397 times
Been thanked: 1114 times
Post by rodbargee »
Scuffmark wrote: Fri Jan 22, 2021 10:27 am
Skub wrote: Thu Jan 21, 2021 2:57 pm How about a lockdown restoration project? Would you hand over £3550 for this one?
https://www.ebay.co.uk/itm/1974-Kawasak ... 0009.m1982
Can't think why but I like that :wtf:
Maybe it reminds me of the bikes I grew up looking at as a pre-teenager?.... Don't think I'd want to pay £3.5k for it though.
I had a H2 b I think it was and spent a fortune on it and eventually let it go, the pipes are 3k ish for a good set (when and if you can find any) Petrol cap (common to the Z1 over £100) much better off buying one thats been done.
ogri
Has thanked: 1269 times
Been thanked: 337 times
Post by ogri »
JackyJoll wrote: Fri Jan 22, 2021 1:28 pm
Ahem, probably more to do with cooling them to help prevent fading?
Would like to hear them pipes :)
weeksy wrote: Fri Jan 22, 2021 12:28 pm Oh there's LOADS i don't like about that.... baiscally 99% of it.
Really?
inewham wrote: Fri Jan 22, 2021 2:29 pm I don't like the tank, looks like someone's done a (very neat) cut and shut job on an old steel tank. Chopped off the rear quarters then welded them back on the other side (inside out).
I wonder if you could tuck your right knee into that cutout, without setting your boot on fire on the exhaust.
ogri wrote: Fri Jan 22, 2021 2:00 pm
I think it’ll help prevent brake fade about as much as farting helps to drown out thunder.
rodbargee
Post by rodbargee »
A Scott
Been thanked: 9466 times
It's a Monster 900 'Restomod' by Rebellions motorworks.
Doesn't the fairing and clipons just make it a 900ss?
I like it though
Nah, the SS and the Monster have totally different frames/swingarms.
I think the Monster frame is more similar to the 851/888 frames.
Druid
Has thanked: 351 times
Been thanked: 1106 times
Post by Druid »
KungFooBob wrote: Sat Jan 23, 2021 7:04 pm Nah, the SS and the Monster have totally different frames/swingarms.
The frames are both made from bits of straight tube welded welded into triangular shapes. I think most people couldn't tell the difference - including me, and I own a Monster :)
The rear suspension is very very different between the Monster and the SS. The SS is a driect link between the frame and swingarm, the Monster has a kind of rising rate linkage with a ride height adjuster.
The frames are very different if you look carefully. It's much much easier to change the belts on an SS.
Where's GP when you need him?
Older SS frame...
Monster 900...
Has thanked: 12565 times
Been thanked: 8521 times
The screen is as much use as a chocolate teapot.
Early Monster frames are closer to 851 frames than 900AS frames, I think the Monster frame is the same as the ST2, dunno why they bothered though, still got a dumper truck engine coupled to a tractor gearbox.
Pgm
Has thanked: 6 times
Been thanked: 83 times
Post by Pgm »
KungFooBob wrote: Sat Jan 23, 2021 6:57 pm It's a Monster 900 'Restomod' by Rebellions motorworks.
First thing that came to mind was a trx 850 Yamaha when I saw this.
Nobby
Has thanked: 175 times
Been thanked: 765 times
Post by Nobby »
Pgm wrote: Sun Jan 24, 2021 5:41 am
