Cleaning IS servicing,ya durty broot.
NBT: Sexy red beast has been bought and heading my way!
Re: NBT: Sexy red beast has been bought and heading my way!
- Has thanked: 12607 times
- Been thanked: 8537 times
Mine follow the yearly servicing schedule
- Has thanked: 20859 times
- Been thanked: 13679 times
No! I just bought some wd40 chain cleaner and now I have a stand it'll be getting good clean and lube over the bank holiday weekend.
Trying to get it booked in for a belt service but it seems bike tuners and mechanics don't reply to emails?
- wull
- Has thanked: 979 times
- Been thanked: 1858 times
Motul C1 and C2 is the muts nuts when it comes to looking after your chain.Taipan wrote: Thu May 04, 2023 6:55 pmNo! I just bought some wd40 chain cleaner and now I have a stand it'll be getting good clean and lube over the bank holiday weekend.Pretty shameful really as I've done over 500 miles on it and haven't touched it other than put fuel in!
Trying to get it booked in for a belt service but it seems bike tuners and mechanics don't reply to emails?![]()
Comes in a kit too! I'll get that next, Cheers.wull wrote: Thu May 04, 2023 9:46 pmMotul C1 and C2 is the muts nuts when it comes to looking after your chain.Taipan wrote: Thu May 04, 2023 6:55 pmNo! I just bought some wd40 chain cleaner and now I have a stand it'll be getting good clean and lube over the bank holiday weekend.Pretty shameful really as I've done over 500 miles on it and haven't touched it other than put fuel in!
- Has thanked: 5954 times
- Been thanked: 3572 times
I used that the other day and was well impressed. This was a spray, leave 30 secs and then wipe off with a rag. I reckon a little bit more effort with a chain brush would have smashed it.
Ahh, I knew it was someone on here that posted about it but couldn't remember who. Thanks for the tip!
Yeah brush is defo better but mine was found dead so just went with a rag this time. I sprayed it on and was initially thinking, well that's doing SFA, I then went over it with a rag and it all came off easy. Right at the end I did a quick second spray on the last section of chain and it started to run dirt out with just the spray pressure so I'd say it was decent stuff. But yeah a brush to get in between the links is best, but what I did was enough to get rid of the proper mank and I'll brush next time. That chain lube was on there all over winter as I left it like that as it stopped the rust in my damp garage so it was very ropey and I didn't use a lot of the spray.Taipan wrote: Fri May 05, 2023 10:09 am Ahh, I knew it was someone on here that posted about it but couldn't remember who. Thanks for the tip!
I spray than spin wheel and rub a toothbrush along the chain, inside and out
Got one of these brushes, which work well.
- Bigyin
- Has thanked: 1436 times
- Been thanked: 2738 times
Off Amazon they came as a set of 4 that i got and cost less than 8 quid ...... your toothbrush probably cost about the same per item
- Has thanked: 2852 times
- Been thanked: 3505 times
What you supposed to do with the other end, tickle your arse.
I use it to agitate and clean the swinging arm and sprocket, but, hey, each to their own!
@Supermofo wd40 chain cleaner worked really well!
Washed the rest of the bike too. It’s quite pretty under the shite! The older I get the more I hate cleaning bikes! I’ll get the guy round who did my mt09 to detail it and acf it.
fb pic
fb pic
asmethurst99
- Has thanked: 1331 times
- Been thanked: 485 times
I gave my CBR a thorough clean up last month with this stuff https://www.google.com/aclk?sa=l&ai=DCh ... g96BAgBEC8(a Lockdown purchase) it’s great stuff and really cleaned up behind the hugger and around the swingarm - I also took some plastics off and cleaned up the block and down pipes - Fan doesn’t come on so often so the rad must have been filthy.
I don’t have anywhere to clean it so have to go to a friends which is a ballache and stops me doing it
I've got muc-off at present which i'm not that keen on. WIll try that stuff when it runs out.
I use Muc-off at the moment too but coming to the end of the 5 litres I bought. Find it so-so, it's OK but not great but I only tend to use it as a pre wash before going at the bike with cloths.
Sdoc is still the best I've used but too pricey, might try the Oxford Mint stuff as it's on special at SBS and just won the Ride best buy thing.
I don't often need to inflict water on the bike,but when necessary I use Sdoc. I know it's expensive,but it works. I have Muc Off,but it leaves stubborn water streaks on painted surfaces,so I don't like it.
Never mind the cost of Sdoc Tarquin,you'll never use a full bottle during your ownership anyway.
Never say I don't look after things!! The muc-off is nearly 5 years old and is in immaculate condition!Skub wrote: Mon May 08, 2023 6:25 pm I don't often need to inflict water on the bike,but when necessary I use Sdoc. I know it's expensive,but it works. I have Muc Off,but it leaves stubborn water streaks on painted surfaces,so I don't like it.
Never mind the cost of Sdoc Tarquin,you'll never use a full bottle during your ownership anyway.![]()
