Has thanked: 9827 times
Been thanked: 10145 times
Taipan wrote: Thu May 04, 2023 2:20 pm Servicing is mandatory. Cleaning is optional! :thumbup:
Cleaning IS servicing,ya durty broot. :P
Has thanked: 10263 times
Been thanked: 6886 times
Skub wrote: Thu May 04, 2023 5:24 pm
Mine follow the yearly servicing schedule :D
Has thanked: 15952 times
Been thanked: 10244 times
Dodgy69 wrote: Thu May 04, 2023 4:42 pm As the chain met Mr Lube yet. 🤷🏻‍♂️
No! I just bought some wd40 chain cleaner and now I have a stand it'll be getting good clean and lube over the bank holiday weekend. :thumbup: Pretty shameful really as I've done over 500 miles on it and haven't touched it other than put fuel in!
Trying to get it booked in for a belt service but it seems bike tuners and mechanics don't reply to emails? :wtf:
wull
Has thanked: 880 times
Been thanked: 1544 times
Post by wull »
Taipan wrote: Thu May 04, 2023 6:55 pm
Motul C1 and C2 is the muts nuts when it comes to looking after your chain.
wull wrote: Thu May 04, 2023 9:46 pm
Comes in a kit too! I'll get that next, Cheers. :thumbup:
Has thanked: 4360 times
Been thanked: 2851 times
Taipan wrote: Thu May 04, 2023 6:55 pm wd40 chain cleaner
I used that the other day and was well impressed. This was a spray, leave 30 secs and then wipe off with a rag. I reckon a little bit more effort with a chain brush would have smashed it.
Supermofo wrote: Fri May 05, 2023 10:08 am
Ahh, I knew it was someone on here that posted about it but couldn't remember who. Thanks for the tip! :thumbup:
Taipan wrote: Fri May 05, 2023 10:09 am Ahh, I knew it was someone on here that posted about it but couldn't remember who. Thanks for the tip!
Yeah brush is defo better but mine was found dead so just went with a rag this time. I sprayed it on and was initially thinking, well that's doing SFA, I then went over it with a rag and it all came off easy. Right at the end I did a quick second spray on the last section of chain and it started to run dirt out with just the spray pressure so I'd say it was decent stuff. But yeah a brush to get in between the links is best, but what I did was enough to get rid of the proper mank and I'll brush next time. That chain lube was on there all over winter as I left it like that as it stopped the rust in my damp garage so it was very ropey and I didn't use a lot of the spray.
I spray than spin wheel and rub a toothbrush along the chain, inside and out
Got one of these brushes, which work well.
Taipan wrote: Fri May 05, 2023 10:56 am Got one of these brushes, which work well.
Posh git.
Bigyin
Has thanked: 1412 times
Been thanked: 2680 times
Post by Bigyin »
Yorick wrote: Fri May 05, 2023 10:59 am
Posh git.
Off Amazon they came as a set of 4 that i got and cost less than 8 quid ...... your toothbrush probably cost about the same per item ;)
Has thanked: 1746 times
Been thanked: 2085 times
What you supposed to do with the other end, tickle your arse. 🤷🏻‍♂️
Dodgy69 wrote: Fri May 05, 2023 2:31 pm
I use it to agitate and clean the swinging arm and sprocket, but, hey, each to their own! :wtf:
@Supermofo wd40 chain cleaner worked really well!
Washed the rest of the bike too. It’s quite pretty under the shite! The older I get the more I hate cleaning bikes! I’ll get the guy round who did my mt09 to detail it and acf it. 👍
fb pic
asmethurst99
Has thanked: 1042 times
Been thanked: 362 times
Post by asmethurst99 »
I gave my CBR a thorough clean up last month with this stuff https://www.google.com/aclk?sa=l&ai=DCh ... g96BAgBEC8(a Lockdown purchase) it’s great stuff and really cleaned up behind the hugger and around the swingarm - I also took some plastics off and cleaned up the block and down pipes - Fan doesn’t come on so often so the rad must have been filthy.
I don’t have anywhere to clean it so have to go to a friends which is a ballache and stops me doing it
I've got muc-off at present which i'm not that keen on. WIll try that stuff when it runs out.
I use Muc-off at the moment too but coming to the end of the 5 litres I bought. Find it so-so, it's OK but not great but I only tend to use it as a pre wash before going at the bike with cloths.
Sdoc is still the best I've used but too pricey, might try the Oxford Mint stuff as it's on special at SBS and just won the Ride best buy thing.
I don't often need to inflict water on the bike,but when necessary I use Sdoc. I know it's expensive,but it works. I have Muc Off,but it leaves stubborn water streaks on painted surfaces,so I don't like it.
Never mind the cost of Sdoc Tarquin,you'll never use a full bottle during your ownership anyway. :lol:
Skub wrote: Mon May 08, 2023 6:25 pm I don't often need to inflict water on the bike,but when necessary I use Sdoc. I know it's expensive,but it works. I have Muc Off,but it leaves stubborn water streaks on painted surfaces,so I don't like it.
Never say I don't look after things!! The muc-off is nearly 5 years old and is in immaculate condition! :lol:
