2012 dodge charger se 0 60
Even my 2013 Harley was keyless!KungFooBob wrote: Wed Apr 19, 2023 10:03 pm Old school, it even looks like you have to use a key to start it!
Bugger, even the manual i found for the Hypermotard has a different pic for the fork tops than yours but its the SP i think which comes with ohlins forks
Correct, putting more oil in reduces the amount of air at the top of the fork, this makes the forks stiffer, but they'll hydraulic lock if you put too much oil in (I know this from doing it with LC forks many years ago)Bustaspoke wrote: Wed Apr 19, 2023 8:53 pmMy SV650S has fork preload & if I ride it down a really bumpy road I can feel the difference between fully preloaded & the preload backed off.Le_Fromage_Grande wrote: Wed Apr 19, 2023 8:28 pm I'm not, my Suzuki has 10mm of preload adjustment on the forks, I can't feel any difference between fully in and fully out, for reference my 35 year old FZ750 has 40mm of preload adjustment, you can feel the difference, but it isn't a big difference.
Correct me if I'm wrong,but does'nt the air gap make a difference,especially if there's no preload adjustment?
^^^^ This ^^^^Skub wrote: Thu Apr 20, 2023 9:00 am Measure the loaded sag (you on the bike) before you start changing anything. You need to know which direction to go.
The can might be a good idea as one guy just told me he ran out and filled it up and it only took 14.7 litres, so it seems there is a lot of fuel in the tank that isn't usable, iyswim? Conversely, the guy below wasn't exactly riding slowly and got 147.4 out of a tank.KungFooBob wrote: Wed Apr 19, 2023 7:42 pm Strap a can of petrol to the seat, ride it till the tank runs dry. Then you'll know just how much you can push the range on the light before refilling from the can.
I think i'd be more likely to spend money on a remap than suspension mods tbh. I can live with the suspension as it is, but the fuelling i'd like improved. All this assumes i'm keeping the bike which in reality is unlikley!Skub wrote: Thu Apr 20, 2023 9:00 am Measure the loaded sag (you on the bike) before you start changing anything. You need to know which direction to go.
I like to fill up every other day and at my local Tesco which is pay at the pump. It'll be pain to have to stop and queue at other garages. Its just what you get used to doing I suppose?weeksy wrote: Thu Apr 20, 2023 12:06 pm It's only an issue if you let it be... i had a 990Superduke that would throw the light on at 70 miles.... you'd do well to get 100 out of a tank... so i didn't try![]()
At the weekend i'd put a 20L can in the car, fill that up and then you've got 4L to throw in each evening to top it up, you'd then get your usual 2 days and not have to re-fill more than your usual number.Taipan wrote: Thu Apr 20, 2023 12:27 pmI like to fill up every other day and at my local Tesco which is pay at the pump. It'll be pain to have to stop and queue at other garages. Its just what you get used to doing I suppose?weeksy wrote: Thu Apr 20, 2023 12:06 pm It's only an issue if you let it be... i had a 990Superduke that would throw the light on at 70 miles.... you'd do well to get 100 out of a tank... so i didn't try![]()
When I do the Iron-man camera bike, I put 2 x 1litre pop bottles of fuel in the tank bagBustaspoke wrote: Thu Apr 20, 2023 2:06 pm Plenty of options for auxilary fuel tanks here
https://www.adventurebikeshop.co.uk/water-fuel-packs/
I have a 20l Jerry can and 2 x 5l cans in garage to fill all the bikes.weeksy wrote: Thu Apr 20, 2023 2:08 pmAt the weekend i'd put a 20L can in the car, fill that up and then you've got 4L to throw in each evening to top it up, you'd then get your usual 2 days and not have to re-fill more than your usual number.Taipan wrote: Thu Apr 20, 2023 12:27 pmI like to fill up every other day and at my local Tesco which is pay at the pump. It'll be pain to have to stop and queue at other garages. Its just what you get used to doing I suppose?weeksy wrote: Thu Apr 20, 2023 12:06 pm It's only an issue if you let it be... i had a 990Superduke that would throw the light on at 70 miles.... you'd do well to get 100 out of a tank... so i didn't try![]()
many many many people.... Chris has a very good reputation.Taipan wrote: Tue Apr 25, 2023 12:57 pm Contacted Mototuning in Dublin about remapping the ECU but he's refered me to CJS Racing in Bristol. Anyone got any experiance of them?
