S1000RR Sport 2022
Has thanked: 2858 times
Been thanked: 3518 times
Re: S1000RR Sport 2022
What bubbles you using.?
wull
Has thanked: 979 times
Been thanked: 1858 times
Post by wull »
Dodgy knees wrote: Sun Jun 12, 2022 7:27 pm What bubbles you using.?
Muc-off
Still using the stuff that came with the muc-off motorcycle pressure washer that I purchased. Seems good enough, no complaints anyway.
Been thanked: 9503 times
Did you not spec the M-Chain?
That never needs adjusting, apparently.
wull
Post by wull »
KungFooBob wrote: Sun Jun 12, 2022 7:36 pm Did you not spec the M-Chain?
In theory yes, but sadly not the case. It’s longer lasting than others but will still require adjusting when needed. I could leave it until it exceeds the 50mm spec but when it does I’d obviously adjust to the lower end of the tolerance.
Apparently BMW have said that it’s more “low maintenance” as oppose to “maintenance free” when shown test results of a chain that had covered 12,000 miles without any maintenance.
wull
Post by wull »
I don’t think there’s anything left in her.
Been thanked: 15509 times
wull wrote: Wed Jun 22, 2022 7:26 am I don’t think there’s anything left in her.
:bblonde: :bblonde: :bblonde:
wull
Post by wull »
dern
Has thanked: 1186 times
Been thanked: 2281 times
Post by dern »
Jinkies. Nice work.
Has thanked: 5970 times
Been thanked: 3574 times
Nice roads them :thumbup:
wull
Post by wull »
Usually this isn’t a corner but I suppose at speed it becomes one.
What I haven’t tried out yet is the launch control, I’ve activated it which is easy enough, when you’re in ride mode pro you press the starter button whilst in neutral and this activates it. It gives you 3 launches but as soon as you perform one and I believe go into 3rd gear and or don’t perform one but go up into 3rd gear it will switch off.
It also won’t allow it if it feels the clutch temps are too high.
Has thanked: 7634 times
Been thanked: 5937 times
Bit late to be blanking the speedo, isn't it?
wull
Post by wull »
Horse wrote: Sat Jun 25, 2022 5:22 pm Bit late to be blanking the speedo, isn't it?
Do you think?
wull wrote: Sat Jun 25, 2022 5:30 pm
Do you think?
After the videos you've posted, that is.
I guess you're hinting that this was taken at ludicrous speed?
wull
Post by wull »
Horse wrote: Sat Jun 25, 2022 5:38 pm
Do you think?
It was purely meant tongue in cheek, as a joke, all of a sudden posting something with the speed blocked out. But it is absolutely flat out, don’t think there’s any more left in it. Gearing and some tuning but can’t be fucked with any of that. Tbh I’m not one for top speed runs and big open flat out sections, ruins a tyre too quickly. Now I’ve taken it flat out I won’t try again.
I will try some launches though, and hopefully a track day soon.
wull wrote: Sat Jun 25, 2022 5:53 pm It was purely meant tongue in cheek, as a joke,
Ok :)
Tee-hee ;)
Although, for me, :o would be my feeling at flat out ;)
Its the on coming car which gets me... :shock:
wull
Post by wull »
180 ???
wull
Post by wull »
Dodgy knees wrote: Sun Jun 26, 2022 3:42 pm180 ???
Yeah but all speedos over read. Bet its barely even 180 in reality. ;)
