S1000RR Sport 2022
- Has thanked: 1749 times
- Been thanked: 2085 times
- wull
- Has thanked: 880 times
- Been thanked: 1545 times
Re: S1000RR Sport 2022
Muc-off
Still using the stuff that came with the muc-off motorcycle pressure washer that I purchased. Seems good enough, no complaints anyway.
- Been thanked: 7534 times
- wull
In theory yes, but sadly not the case. It’s longer lasting than others but will still require adjusting when needed. I could leave it until it exceeds the 50mm spec but when it does I’d obviously adjust to the lower end of the tolerance.KungFooBob wrote: ↑Sun Jun 12, 2022 7:36 pm Did you not spec the M-Chain?
That never needs adjusting, apparently.
Apparently BMW have said that it’s more “low maintenance” as oppose to “maintenance free” when shown test results of a chain that had covered 12,000 miles without any maintenance.
- wull
- Has thanked: 5451 times
- Been thanked: 13095 times
- wull
- dern
- Has thanked: 1016 times
- Been thanked: 1774 times
- Has thanked: 4362 times
- Been thanked: 2852 times
- wull
Usually this isn’t a corner but I suppose at speed it becomes one.
What I haven’t tried out yet is the launch control, I’ve activated it which is easy enough, when you’re in ride mode pro you press the starter button whilst in neutral and this activates it. It gives you 3 launches but as soon as you perform one and I believe go into 3rd gear and or don’t perform one but go up into 3rd gear it will switch off.
It also won’t allow it if it feels the clutch temps are too high.
- Has thanked: 6196 times
- Been thanked: 5088 times
Bit late to be blanking the speedo, isn't it?
- wull
After the videos you've posted, that is.
I guess you're hinting that this was taken at ludicrous speed?
- wull
It was purely meant tongue in cheek, as a joke, all of a sudden posting something with the speed blocked out. But it is absolutely flat out, don’t think there’s any more left in it. Gearing and some tuning but can’t be fucked with any of that. Tbh I’m not one for top speed runs and big open flat out sections, ruins a tyre too quickly. Now I’ve taken it flat out I won’t try again.
I will try some launches though, and hopefully a track day soon.
Ok
Tee-hee
Although, for me, would be my feeling at flat out
- Has thanked: 2552 times
- Been thanked: 6255 times
- wull
- wull
