Sex wee
Re: Sex wee
I mean the fact the headers poke out left and right, every other Guzzi (and indeed Beemer) has them pointing forwards.
I know why they've done it (means you can feed the engine from a big air box under the tank) it just looks weird.
Has thanked: 8005 times
Been thanked: 5664 times
Re: Sex wee
wull wrote: Sun Sep 25, 2022 9:52 am
Mr. Dazzle wrote: Sun Sep 25, 2022 8:50 am I still can't cope with the 90' turned cylinder heads. :D
I didn't notice when they first launched this engine, but now I can't unsee it.
I think they’re 45’, 90’ would be straight out boxer like.
If you 'flattened' the Guzzi engine out to make a boxer then the exhaust is rotated 90° clockwise looking at the heads end on innit? From pointing forwards to down. :hmmm:
Has thanked: 2554 times
Been thanked: 4159 times
Re: Sex wee
I think the trick they've done with the heads (and inlet/exhaust) is a smart move and doesn't look out of place. The edge of the cylinder head is still the widest point of the engine and the exhaust won't touch any body parts, so I'm all in favour. Die-hard Guzzi purists may object, but I don't fall into that camp. At a stroke they've made the engine more modern looking and substantially increased its performance.
What's not to like?
Bigjawa
Has thanked: 225 times
Been thanked: 969 times
Re: Sex wee
Post by Bigjawa »
Yorick wrote: Sat Sep 24, 2022 9:48 pm About as exciting and fast as a Mondeo.
Ever drive one of the later 5 pot turbos?
We got one up to near 400 bhp for a punter.😉
Anyway, dunno what to make of that Guzzi, it's like they've made a Heinz 57 out of all the other manufacturers. It's like a tin of London Grill.
wull
Has thanked: 976 times
Been thanked: 1846 times
Re: Sex wee
Post by wull »
Count Steer wrote: Sun Sep 25, 2022 10:00 am
I edited my comment when I realised it was a 90’ L like twin. But the heads as we look at them are 45’ from vertical
Re: Sex wee
That's still not my point ;)
On every other Guzzi the inlet is at the rear of the cylinder and the exhaust at the front. In this bike the inlet is in the centre and the exhaust is on the left/right depending on which cylinder you look at. Everything is spun 90'.
They've done it for good reasons, it just seems "off" to me
Been thanked: 1227 times
Re: Sex wee
Motorcyclists make an awful lot of fuss about what the exhaust system looks like.
Re: Sex wee
JackyJoll wrote: Sun Sep 25, 2022 12:37 pm Motorcyclists make an awful lot of fuss about what the exhaust system looks like.
Probably because it's out in the open (especially on a Guzzi) and is a major part of the styling? It's not like a car, where the only bit you see is the tailpipe (on an ICE vehicle, obvs).
Has thanked: 7585 times
Been thanked: 5912 times
Re: Sex wee
I hadn't noticed until ^ that!
It's an interesting compromise - the exhaust has to be extended forwards instead if the intake path being extended out.
However, it does allow more freedom on size and location of the radiator.
Edit: if you can't cope with 90°, a CX500 would bring you out in hives :)
22° from inline with the crank
Re: Sex wee
There's also something vaguely mechanically satisfying about an arrangement where the crank and shaft rotate in the same plane so to speak. (Shame the power has to do a 90° turn at the back wheel but you can't have everything. :D ).
Dickyboy
Has thanked: 698 times
Been thanked: 528 times
Re: Sex wee
Post by Dickyboy »
Pah, Guzzi couldn't even be bothered to go the full hog & reverse the cylinders fully
Like the eagles facing backwards too
wull
Re: Sex wee
Post by wull »
Mr. Dazzle wrote: Sun Sep 25, 2022 12:28 pm That's still not my point ;)
That’s my fault for not even reading your comment correctly, just realised you’re talking about the cylinder head as opposed to the cylinders themselves. I don’t think it makes any odds so maybe more for access or space itself depending on what’s going on.
Demannu
Has thanked: 65 times
Been thanked: 1234 times
Re: Sex wee
Post by Demannu »
Mr. Dazzle wrote: Sun Sep 25, 2022 9:56 am I mean the fact the headers poke out left and right, every other Guzzi (and indeed Beemer) has them pointing forwards.
Ahem!!
Gs1250
Scootabout
Has thanked: 584 times
Been thanked: 371 times
Re: Sex wee
Post by Scootabout »
Count Steer wrote: Sun Sep 25, 2022 9:29 am If it has decent luggage available to fit it would be a nice touring option.
Ah, there's the rub. It doesn't look as if it would be easy to fit luggage to it.
Re: Sex wee
Scootabout wrote: Sun Sep 25, 2022 8:33 pm
I thought not too, which would rather limits its usefulness. However, a quick rootle and there are some pics of panniers v neatly attached that look like they're styled/designed for it. :thumbup:
Re: Sex wee
Demannu wrote: Sun Sep 25, 2022 8:11 pm
Ahem!!
Gs1250
Ha!
So it does. There's so much err...'extra'....going on with that bike I didn't notice :D
Scootabout
Re: Sex wee
If Santa brought one I wouldn't stuff it back in his sack.
