Page 2 of 3
Re: ZXR 750 L1
Posted: Sun Feb 06, 2022 7:54 pm
dern wrote: Sun Feb 06, 2022 6:11 pm The best thing about doing the clearances on this bike is that the rockers push to one side so you don't have to remove the cams. Huge time saver. You can see the springs in this picture...
Same as the ZZR1100,it makes valves clearances a doddle.
Re: ZXR 750 L1
Posted: Sun Feb 06, 2022 8:27 pm
I'll tell you what makes valve clearances a doddle.
Pushrods!
Re: ZXR 750 L1
Posted: Sun Feb 06, 2022 8:41 pm
Hydraulic tappets!
Re: ZXR 750 L1
Posted: Sun Feb 06, 2022 8:43 pm
by Le_Fromage_Grande
I'll tell you what makes valve clearances a doddle, two strokes.
Weird having rockers with bucket and shim valves.
Re: ZXR 750 L1
Posted: Sun Feb 06, 2022 9:40 pm
by BBB
How do the rockers slide? I'm struggling to visualise it as they look bolted in place.
Re: ZXR 750 L1
Posted: Sun Feb 06, 2022 9:42 pm
I assume they slide on the shafts with the springs on them (don't confuse the followers with the cams/lobes)
Desmo followers on the aircooled heads slide on the shaft once a clip is removed.
Re: ZXR 750 L1
Posted: Sun Feb 06, 2022 9:50 pm
by BBB
Got you, didn't see the followers, had stupidly thought shim and bucket. Makes sense now, thank you.
Re: ZXR 750 L1
Posted: Mon Feb 07, 2022 12:07 am
by mangocrazy
Mr. Dazzle wrote: Sun Feb 06, 2022 8:27 pm I'll tell you what makes valve clearances a doddle.
Pushrods!
Probably because you have to adjust them every five minutes... :D
Re: ZXR 750 L1
Posted: Mon Feb 07, 2022 8:27 am
by dern
KungFooBob wrote: Sun Feb 06, 2022 8:41 pm I'll tell you what makes valve clearances a doddle.
Hydraulic tappets!
True. I'll do a mondeo next ;)
Re: ZXR 750 L1
Posted: Mon Feb 07, 2022 8:29 am
by dern
Thanks to a superb facebook zxr group I've now got a new zx7r sleeve with adapters and a replacement pivot bolt on the way. Didn't mention the pivot bolt but the threads have been forced at some point and are somewhat damaged.
Re: ZXR 750 L1
Posted: Mon Feb 07, 2022 8:37 am
Pushrods!
dern wrote: Mon Feb 07, 2022 8:27 am
Hydraulic tappets!
My Enfield has pushrods and hydraulic tappets.
WIN/WIN!
Re: ZXR 750 L1
Posted: Mon Feb 07, 2022 9:11 am
KungFooBob wrote: Mon Feb 07, 2022 8:37 am My Enfield has pushrods and hydraulic tappets.
WIN/WIN!
They really don't want those valves to move quickly.
Re: ZXR 750 L1
Posted: Mon Feb 07, 2022 8:11 pm
by dern
Looks like whoever did the swing arm bearings last time lubricated them with copperslip!
Re: ZXR 750 L1
Posted: Tue Feb 15, 2022 7:31 pm
Should have bought this one instead.
No restoration required :)
https://iconicmotorbikeauctions.com/auc ... -in-crate/
Re: ZXR 750 L1
Posted: Tue Feb 15, 2022 7:42 pm
by mangocrazy
Were the model designations different for Murkins? That is clearly a ZXR750-K2 but the auctioneers are touting it as a ZX-7R.
Re: ZXR 750 L1
Crazy dough.
Re: ZXR 750 L1
Posted: Tue Feb 15, 2022 7:44 pm
Skub wrote: Tue Feb 15, 2022 7:42 pmCrazy dough.
Re: ZXR 750 L1
Posted: Tue Feb 15, 2022 7:49 pm
by mangocrazy
Thankyou for that post - it made me remember that I have a loaf that's been in the airing cupboard for too long and needs to go in the oven... :mrgreen:
Re: ZXR 750 L1
Posted: Tue Feb 15, 2022 7:59 pm
Yorick wrote: Tue Feb 15, 2022 7:44 pm
I want toast now. :(
Re: ZXR 750 L1
Posted: Tue Feb 15, 2022 8:02 pm
Skub wrote: Tue Feb 15, 2022 7:59 pm
