Page 8 of 8
Re: Zzr1100d
Posted: Thu May 22, 2025 9:33 am
Ssray wrote: Thu May 22, 2025 9:24 am
KungFooBob wrote: Tue May 20, 2025 8:33 pm 51psi, is that a typo?
41 psi fat fingers....
Lol, I did think 51 was a bit extreme:)
Re: Zzr1100d
Posted: Sun Jul 27, 2025 10:42 pm
by Ssray
It's been handling a bit odd recently, the head bearings were a bit loose, I'd adjust the slack out(eventually) but then they seemed to drag.
For some reason I thought I'd regrease the top set but not bothering with the bottom ones, it felt better and I used molybdenum disulphate grease, then I thought I'd do the bottom set (after 2 weeks) cleaned the old manky grease and replaced with the same
Managed to get them adjusted correctly first time and it's much better.
More direct steering and no wobble
Re: Zzr1100d
Posted: Mon Jul 28, 2025 5:30 am
by ZRX61
I recently knocked a 2in piece of 1/4in drill rod off of something & I heard it rattle down inside the ZX11 fairings.. bugger...
Looked under the bike, no sign of it, double bugger...
A few days ago I was moving the ZRX11 & spotted the piece of drill rod laying next to the Baxley front wheel stand/chock. No idea how the hell it ended up by the other bike, but happy I don't have to pull the fairings looking for it.. unbuggered! :)
Re: Zzr1100d
Posted: Mon Jul 28, 2025 10:35 am
by Supermofo
ZRX61 wrote: Mon Jul 28, 2025 5:30 am I recently knocked a 2in piece of 1/4in drill rod off of something & I heard it rattle down inside the ZX11 fairings.. bugger...
Dropped items in the garage enter a parallel universe for a while, re-entering where they have no right to.
Re: Zzr1100d
Posted: Mon Jul 28, 2025 10:46 am
Supermofo wrote: Mon Jul 28, 2025 10:35 am
Years ago I dropped one of the bobbins for the Abba stand. A substantial item,not in normal pingfukkit territory at all. The garage has been cleared and that thing never reappeared,not even after I had to buy another kit.
This is why dropping things in the garage is such a moment of complete horror,there's always a chance you'll never see the item ever again.
Re: Zzr1100d
Posted: Wed Jul 30, 2025 1:08 am
by ZRX61
One of the top-hat washers from the front tank bolts is still AWOL under the tank someplace...
Re: Zzr1100d
Posted: Sat Aug 23, 2025 6:24 am
by Ssray
I've always thought the the rear shock/spring was too harsh.
I've been through a few online things that work it out and it appears that the spring I have is approx 500pb/inch fory weight etc it should be 450lb/inch
I measured static sag etc the other day.
From shock topped out to bike weight on it is 30mm
With me on its 20mm
This is with no preload on the spring,as I found it much harder wit the sugged 15mm of preload.
I need to get the shock out remove and measure the spring
Re: Zzr1100d
Posted: Wed Sep 03, 2025 4:20 pm
by Ssray
Mot passed today, I popped in to see when they had space and it was there and then.
I managed to see the weight when he was weighing it
Front end 122kg
Rear end 122kg
So 50/50 weight balance unladen by myself, I'm not sure if that means it's 244kg total or what?
Kawasaki say it's 256kg wet, mine has a full tank minus 50 miles so maybe 2kg in fuel
Re: Zzr1100d
Posted: Fri Oct 03, 2025 11:16 pm
by ZRX61
I recently saw someone call the ZX11 a "Ballistic Couch"
I kinda like that :)
